I haven't seen one around here in at least 20 years.
Roy's on Stevens Avenue next to Pat's meat market in Portland, Maine can fix ya right up.
Those 12AT7 's were always in need of friendly persuasion and the 6AT7's always seem to be short lived when used in place of the 12AT7's could never figure that one out.
I can't get just the wheel bearings for my car, I have to buy an entire assembly. On the plus side, it cuts down on the need for really skilled labor to replace, a parts changer can do it. That saves on labor in a shop, but I do my own work, so it doesn't benefit me much.
They are not like the old cone type bearings anymore. Many manufacturers make them like that. You COULD replace just the bearing, but you need a press & proper press plates to change it. Then you need to find a bearing supplier. Cheaper & faster to replace the whole hub.
 , rear drum brakes went over 100K. )
Plus most FWD/AWD cars and 4x4 trucks have the ABS sensors built into the hub. The sensors are often very delicate so replacing them without special tools is a no go. You think not being able to replace the bearings is irritating? How 'bout replacing an otherwise serviceable hub assembly because a $20 sensor chit the bed.
I just did both hubs, left and right on my Canyon at 110K. Have to pull them to change out brake rotors anyways and I've been having intermittent ABS issues so I but the bullet and repalced the hubs as well. They weren't horrible bearing wise but I didn't trust them for another 50K (which is what I've been getting out of my front brakes, 3rd set since the truck was new in 2005. I'm not complainin', rear drum brakes went over 100K. )
Also similar to brake calipers. For $50 I can exchange my calipers with rebuilt originals. A little caliper paint and on they go. Not worth my time to rebuild them with a traditional caliper rebuild kit IMO.
One point worth mentioning is even though it may not feel like your repairing vs replacing, most of the time rebuilt hub assemblys are what you're buying so just the bearings and seals have been replaced and a new ABS sensor fitted. They just deny you the fun of doing the rebuild yourself.
Hahahaa I wonder how few people still know how to read tube designations and understand the joke there
Vacuum tubes. They used to be very common in old radios, tv's, Amplifiers (as a matter of fact, they STILL make the best quality amplifiers), etc. They were replaced for the most part by solid state electronics (transistors).Okay. What da hell are you guys talkin bout anywho?
T
You have to be a geezer to understand good things such as generating your own soft xrays or warming your hands over the finals.
 I'm getting there but still not to geezer status.
I'm 44 and Jeremy is younger yet.I'm getting there but still not to geezer status.
Man - it does sound old when I actually type it out.
$200 coffee maker:Anyway, I dug up the number for customer service to ask where I could send it for service. It's a $200 coffee maker so, not exactly what I would consider to be a "throwaway item." The customer service rep flatly told me that they do not repair products. Even if you bring something in under warranty they just trash it and give you a new one.That's crap
 Some funny stuff. I guess I was wondering about all the testing stuff and the numbers. But I am now catching on. Takes me a little while sometimes.
The first number was usually filament voltage and the last number was usually the number of parts inside the tube.
Fourty four! Holy chit Jags, you are older than dirt!
The advantage for amplifiers is that tubes distort in harmonics (a variation of the same note only higher or lower on the scale). This is a plus when amplifying music.
