Well, I don't see any questions either, just comments about what some say and what he says. If the question is open or closed. Closed.
Even in a pre-epa I'd be very skeptical that the stove heated faster or burned more efficiently with the door open. It would be operating like an open fireplace, probably sucking hot air out of the house faster than its adding heat.
There are 2 types of efficiency, combustion efficiency and over all efficiency, as in how much heat is getting in the house.
I was referring to combustion efficiency and your right the extra combustion efficiency some of it was being flushed up the flue due to the door open allowing higher rate of air flow thru the stove. Your definately wasting heat but a fire burnng hotter has a higher combustion efficiency and you are getting more heat outo f the wood but a portion of it is going up the flue.
A key point to these new EPA stoves is that by raising the temps in the fire box the wood can burn at a very low input air setting. By slowing the air flow thru the stove really slow the heat residual time is increased and allows more time to let heat radiate out into the room before it goes out the flue. Thus we see low flue pipe temps compared too stove top temps.
If your burning your stove at a low input air setting take note of the stove pipe temp then open your door and watch as the stove pipe temp will rise as the heat your flushing up the flue is causing that to happen.
The Sierra Club would allow a wood stove? I figured they all lived in dirt huts becoming one with nature.
My question: if a person joins the Sierra Club in hopes of making the world a better place in which to live, mightn't they also use a newer EPA-approved, less-polluting stove? I don't know what the OP has, just asking...
Sorry Sprinter but the answer is: WHAT IS leaving the door open?I'll take wood stoves for $1,000 Alex.Answer: Leaving the door open. Question: What is the worst way to operate a wood stove?
LOL I guess I'll never be on that show!Sorry Sprinter but the answer is: WHAT IS leaving the door open?![]()
Anybody that thinks leaving the door open on a wood stove (even if it has a screen) is a good idea should really come here and read..then read some more.Thanks to all for excellent responses to a what was a confusing question. I sent the guy at Sierra Club a page and a half of what I thought were most succinct responses and he can write his reply from that. The Sierra Club does have some really good pages about wood stoves, and their first recommendation is to upgrade to EPA certified stove. One thing they missed is emphasis on dry wood, but overall I thought their advice to their members was really good and had very positive attitude towards wood and pellet heating as a low carbon alternative to fossil fuels. Here is link:
http://www.sierraclubgreenhome.com/...nditioning-hvac/woodstoves-and-pellet-stoves/
Will post Sierra Club's reply as soon as he pulls it together.
Hmm. Overall not a bad article, but this sentence is not correct. "The ideal air supply is achieved with the door closed and the air supply adjusted to achieve a lively fire." That is not quite correct, especially if one is trying to burn 24/7 cleanly. In that case one is more likely to be adjusting the air supply to achieve a gentle, lazy fire. A lively fire is fine if you want to watch flames. But it's often not as efficient.
... especially if one's wood supply is less than ideal.
