wood-fan-atic said:Are you SURE the Huskee 22 ton isnt BOTH horz/vert??? I got mine a month ago ($999 with $150 rebate in form of TSC gift card), and it is ,INDEED both vertical and horizontal.
I don't think anyone stated that the 22-ton doesn't go vertical. There was a complaint that the toe plate is too short for vertical splitting.
Got Wood said:While I am quite happy with it I have two small complaints (which may be common with other brands IDK):
1) I prefer splitting in vertical mode. The plate that the log sits on is too small (may be ok for horizontal but I dont use it that way). This is a minor complaint but it certainly would be nicer if the plate was bigger
2) I have had the hydraulic return hose spring a leak twice, both times right near the connection to the filter. Others have commented in this forum about similar problems.
