I'd go for some hydronic heat version.
You'll need a LOT of wood regardless of what you are going with. Some branches and a dead tree here or there won't make it thru one winter.
You need to identify a consistent much larger quantity of wood supply before proceeding with a wood fired system, imo.
, I will look into themYes, I burned around 9-10 stairs (3 cords) last year in the third of the building in which we currently reside, so your estimate is quite conservative. In reality it might be double that with the two households. I also have continuous fuel hitting the ground here which I don't want to burn in the house and species like poplar and chestnut and that's what will find its way to the firepitSounds to me like a 6-8 cord a year burn rate could be a conservative estimate for those spaces?
Firepit would be the hungriest burner (aka the first place you'll cut back on burning when wood supply is not overly packed full.)
We don't really need consistent temp, mainly comfortable common areas...we've gotten quite accustomed to living in the cool temps....none of us enjoy tropical heat. These buildings are very thermally inefficient and we need to improve that too. I know there is no way to heat both buildings with a single stove.If you’re looking for specific temperature control you may want to look at something like a mini split for your studio and keep the stove in the large common areas.
A stone building that large will be tough to get up to temperature and then keep it there. With compartments and 2 levels might make it impossible to heat with a single stove.
Most properties here are zoned heat pump and they burn "Fuel" which is an oil/ diesel product, which we want to avoid burning, because of cost and pollution. What powers the pump is another matter...my neighbor says his elec bill is always reasonable...ours isn't...water seems like a better option, but maybe because we have so much experience with it. Our houses in england are natural gas and those bills get pretty high tooWith a potential area of about 4,100 sq ft, the heating requirements being described I definitely would look at zoned heat pump systems. Heating that amount of space with wood will get old, quickly, especially if not well insulated in parts. Put a woodstove or high-efficiency fireplace in the area where most of the time will be spent and the fire view will be appreciated.
Yes, water central heating is what we know well as most homes in England are hydronic...and the first thing my wife suggested for piping heat around
thanks everyone for those super quick responses, I will look into them
as far as supply, wood is far and away less expensive than electricity here; I buy in the majority of my annual wood fuel anyway and am surrounded by thousands of hectares of forest...supply will not be a problem...there are many vendors
after I posted, I found this fairly recent vid
the long and short is I don't really want to make 2 or 4 fires per day!
I doubt I'll have a draft issue with the height of these buildings
but this vid has kind of put me off the Tulikivi since I posted
Yes, I burned around 9-10 stairs (3 cords) last year in the third of the building in which we currently reside, so your estimate is quite conservative. In reality it might be double that with the two households. I also have continuous fuel hitting the ground here which I don't want to burn in the house and species like poplar and chestnut and that's what will find its way to the firepit![]()
?? A heat pump is "fueled" by electricity. In France, would this be from nuclear power?Most properties here are zoned heat pump and they burn "Fuel" which is an oil/ diesel product
Typically I think these are ammonia absorption type refrigerators. At least that's what I recall our campers having. I haven't heard of this being used for large heat pump systems but maybe in France? I did find info on them.There are (nat.)gas-based fridges too in Europe. At least there used to be, and there still are in campers.
Maybe it's similar to that if not a misunderstanding?
In northern Michigan and just inherited a beautiful Tulikivi fireplace with our new house. I love it so far, but would like to hear from other Tulikivi owners to learn best practices, maintenance, things to avoid, etc. I have a model TU2200. According to my chimney tech., these are pretty rare.
We have a 2200 also. It pairs well with our well insulated passive solar home in Southwest Montana. We typically fire it in the morning and in the evening November to February and once in the evening in March and April. In the summer months the chimney gets swept and the clean outs on the 2200 are opened and the interior is vacumed and brushed with a HEPA fireplace vac. Never any buildup of creosote, justIn northern Michigan and just inherited a beautiful Tulikivi fireplace with our new house. I love it so far, but would like to hear from other Tulikivi owners to learn best practices, maintenance, things to avoid, etc. I have a model TU2200. According to my chimney tech., these are pretty rare.
![[Hearth.com] Tulikivi owners [Hearth.com] Tulikivi owners](https://www.hearth.com/talk/data/attachments/331/331687-e55ca61f623392100015c9ce3115448e.jpg?hash=vegsjbh5iE)
Looks great! What size home are you heating with this?We have a 2200 also. It pairs well with our well insulated passive solar home in Southwest Montana. We typically fire it in the morning and in the evening November to February and once in the evening in March and April. In the summer months the chimney gets swept and the clean outs on the 2200 are opened and the interior is vacumed and brushed with a HEPA fireplace vac. Never any buildup of creosote, just
fly ash. The best size wood is three inches and never any round pieces. It doesn’t need anymore maintenance other than the annual cleaning and the weekly emptying of the ash.
