HI All!
I have had an exciting journey into heating with wood, and with the help of all the amazing advice from this forum, am about to enter my 5th year heating an old 2 story farmhouse primarily with wood. The walls and windows are well insulated, but the floor and ceilings are not the tightest. I also have a 2 zone heat pump. The house is about 2300 sq feet, but I close roughly half of that off when I do not have guests. My chimney is tall and the stove tends to want to run hot on me, but I have learned to regulate that with experience.
It all started in 2011 when I bought a used VC Defiant Encore cat stove as a newbie. Boy, did I get an education in wood stoves, fire safety and stove cement. It all worked out fine in the end, and I have since done a complete rebuild including a new fireback, refractory assembly, cat, damper plate etc etc.
Here's my question.... I LOVE this stove when it's working properly. The first season after rebuild (4 years ago) it was amazing... I was running a brand new Condar steelcat and was able to get an absurd amount of heat with very little fuel and almost no smoke. However, after that first season, the stove has always been finicky and is increasingly problematic. I have replaced the cat (back to ceramic), and the gaskets, but the stove doesn't always go into cat burn as it should. I am burning nice dry mostly oak wood, draft is good etc etc. The cat clogs often, and the cover is dry and fragile.... I've had to replace it twice. There are some other issues with the stove... like a wrung off bolt that secures the cat access panel in the rear of the stove (which now has a steel drill bit broken off and stuck in it thanks to our local VC dealer's repair guy), making cat checking and cleaning difficult.
There is a used Jotul 12 CB for sale at a reasonable price in my area. I haven't been to see it yet, but I believe that it is the non cat version. Here are my questions: How does this stove compare to my VC encore catalytic? Should I give up on cat stoves entirely and try the Jotul non-cat stove? Have any of you made this shift and seen a big difference? Given that the VC has lots of wear and tear, was once overfired (just before the complete rebuild) and may have some minor warping, and the refractory box already seems dry, hard and fragile, is it worth it to do another tedious teardown/rebuild on the VC? Or is that VC, especially in it's old and abused state, just a problematic stove generally and I should be saving my pennies to get a newer more reliable catalytic stove? If so what do y'all recommend?
Thanks so much for your thoughts and advice!
-joe
-joe
	![[Hearth.com] Vermont Castings Defiant Encore cat vs Jotul 12 CB [Hearth.com] Vermont Castings Defiant Encore cat vs Jotul 12 CB](https://www.hearth.com/talk/data/attachments/183/183139-2ceb2acc09542f7470eb461475e7e67d.jpg?hash=IjQhaFez_2)
![[Hearth.com] Vermont Castings Defiant Encore cat vs Jotul 12 CB [Hearth.com] Vermont Castings Defiant Encore cat vs Jotul 12 CB](https://www.hearth.com/talk/data/attachments/183/183140-f513f570ebabf863477b3d7dd8a9326d.jpg?hash=R1ak8hOCeh)
![[Hearth.com] Vermont Castings Defiant Encore cat vs Jotul 12 CB [Hearth.com] Vermont Castings Defiant Encore cat vs Jotul 12 CB](https://www.hearth.com/talk/data/attachments/183/183141-3a3289b7cfba389be9a0c55ea1c85c6a.jpg?hash=1h9I6E-nOs)
