Hi, all. First post here, so bear with me... I saw other posts about things I never would've thought would be posted in this community, so I hope mine applies (and sorry for the book).
I live in the Midwest in a small town where the county name is literally "Clay County," so it's by no surprise that the soil here has clay in it (a rough estimate might be 20% clay but the soil survey indicated something about "Muren silt loam, 2 to 6 percent slopes, eroded"--it also indicated a 12"-24" depth to the water table but understand that the survey I was looking at applied to the entire county--not my specific lot--so either it's overly general or else I'm an idiot. I mean, I do think I have a high water table but 1-2 feet? That's a little extreme, even considering my wet basement.
Anyway, I own the mortgage to a home that I closed on as a renter after my landlord decided to sell it to me after being diagnosed with cancer that he later passed away from. Me being a naive twenty-something at the time, I didn't realize a leaky basement could be one of the most expensive repairs you can have as a home owner. At the time of renting, the basement didn't even have a working sump pump and the outbound line that was connected to it was a rusty 1.25" galvanized water pipe. Gotta love old homes... I was lucky that the basement only flooded once during my entire time of living here but as soon as I closed on the sale, I replaced the broken pump with a $500.xx metal solid-grinding pump (I've had it now for about 8 years I believe, and it's been a beast). I also got with a local excavator contractor to replace the 1.25" rust tube with a good 2" PVC line that's connected to the city rainwater drain line. That helped things alot.
This basement was dug-out after the home was built back in the 50s (to my understanding). The walls were initially retention walls with original home footers sitting behind about 1-2 feet of earth for support. As if that wasn't enough of an issue, these "walls" were built with old ceramic (rigid) blocks with horizontal voids. Each time it would rain, water would come in like a hot knife going through butter. The heavy rains were damn near terrifying for me (especially for me being a new howe owner).
Here's what the orginal basement looked like after a 2"+ rain amount within 3 hours with the old walls:
As you can imagine, I didn't want to keep going through that... I'm still getting over that one. Ha. But after understanding the concept of bowing walls (2 of which existed in that original construction), I set out to replace 2 entire sides of the basement with a local contractor as the 2 sides leaked the most and had the bows.
Fast-forward to this past November and I wrapped up the 2 new wall construction with the following work being done by the contractor for $36k:
Here's what the basement looks like now with about 0.5-0.75" of rain in one setting:
Better, but far from perfect.
Sadly, this week we not only had one day where we received 0.75" of rain but it wasn't a day after that when we got hit with another 1.5"+... Oh boy.
When we get that kind of rain, a section of yard that my neighbor owns pools up to such an extent that water from it eventually creeps over against my house and eventually sinks into both my periemeter drain and eventually, my basement via little waterways through the joints and corners.
Here's what that looked like:
I always planned on doing something about the neighbor's creeping water, so once that big rain finally ended the other day, I went to my local Menard's to buy 100 feet of corrugated-perforated 4" drain (black) pipe with a small circular surface grate that has the diameter port size of a baseball. A specific spot in my driveway is where the creep-over happens, so I decided to place the surface grate right at the location at surface level (with a small half-moon berm built up around it to prevent water from bypassing it). I then buried the drain line outward towards the street rainwater drain with the street drain entry being about 1-1.5 feet below the grate portal height. I tested for gravity in the trench I dug before putting the pipe in and it carried the water away despite the little grade I had to work with. So I went with it and put the pipe on top of a small bed of pea gravel and topped everything off with a mixture of both pea gravel and driveway rock (to both prevent compacting but also to extend the amount of rock I had available to me to work with). We'll see if it works. I think it will as long as the water enters the port.
So assuming for a second that the creep-over issue is fixed, that leaves the remaining issue of water entering the basement.
I've spoken to the contractor that did the 2 basement walls about the water I'm seeing and he believes it's coming in from the joints and the corners where the old basement meets his new walls. I think he's basically correct but he's suggested installing some French drains as a means to capture the water, which I'm leaning towards doing as long as they make use of both drip board as well as weep holes. Anything that escapes that shouldn't be much whereby the water that is captured just gets pumped out.
My questions for any of you with experience with this are as follows:
Thanks in advance.
- A complete dig-down from the outside using a backhoe to a depth that was deeper than the current slab depth (by at least 1-2 feet).
- Ripped both of the problematic sides out completely.
- Ripped out various segments of erroneous block and dirt composite areas I didn't need or want (i.e. - the basement had lots of useless areas that were removed to expand the overall size). In the end, this almost doubled the space of the basement.
- Poured 2 new footers that were, at a minimum, 2.5 to 3 feet wide by about 2 to 2.5 feet deep--these things were HUGE.
- Rebar inserted up to hip height in the new footers.
- Placement of actual concrete blocks and mortared in place.
- External walls were covered in roofing cement and that was then covered with insulation panels. The cement wasn't as thickly-applied as I would've liked but the panels were basically 0.5" Styrofoam paneling they used to protect the roofing cement when the pea gravel was poured into the trench.
- Installation of a perimeter drain which is also connected to an additional sump pump that was also installed in the basement in the corner of the two new walls making my basement have 2 sump pumps of the same type.
- Everything was then covered on the outside by pea gravel to facilitate drainage and prevent hydro-static weight.
- Have any of you installed any internal basement drain lines that use both drip board encapsulation as well as weep holes, and if so, how did they do? For reference, I'm thinking about this kind of internal drain system:
- What impact to any water should I expect from a good dehumidifier? I haven't had one in this basement during my entire time living here. I always planned on getting one but due to other obligations, never got to it. Well, that's about to change and my eyes are set on this model but I'm a little concerned about what kind of ding I should expect to my electric bill from it. (My basement is about 900 square feet, so judging from the product info, it seems overkill but that's on purpose--I want a big gun if it means taking out a lot of moisture, quicker.)
- My yard has very little grading capability--definitely not enough to reduce the amount of water I see my sump pumps deal with. It's taken about 2-3 days to get to a normal "dribble" of water at the perimeter drain pipe after that last big rain, and since my downspouts are already directing water 10-15 feet away from my house, any subsoil drainage options I have left appear to consist of using either a dry or wet well... I want something that doesn't require a powered pump to work, so given the clay content in my soil, is there any hope of making a dry well successfully affect any of the water penetrating my basement or reducing that which my perimeter drain has to deal with? Have any of you ever used a dry well for purposes like that, and if so, how did you proceed? Did it do any good? Given the amount of water I see my pumps deal with during heavy rains and thereafter for about 2-3 days minimum, I think the well would have to be no less than a 500 gallon capacity but getting the water captured into it is the problem. I'm not sure how that might work in my situation and if you think this is an option, I'd love some guidance on ways I might proceed with it.
Thanks in advance.
