Also planning to rock that fire place and clean up the firebox but not much point in all that until that stainless liner is in. I'm really amazed at the amount of heat this thing throws at such a low burn...AMAZING!
You know, the thought of sliding a couple sheets of stainless in there did cross my mind! It is on an exterior wall so i'm sure anything would help out. I'll give that some more thought when it warms up enough.I would try to insulate that old fireplace as much as possible if it is on an exterior wall. Maybe you could get Roxul and cement board on the back wall.... not sure what you can do about the sides, but even a sheet of sheet metal might help a little with heat reflection.
If it's an interior chimney, let it be... it's all good in that case.
You know, i'm positive a liner would only add to this great stove. I do have just a small bit of smoke spillage when i open the door to add wood...so, i'd imagine the draft could be better. It's hard to tell at this point because we have had a steady 20 mph wind with heavy gusts since i lit the stove Friday night. On top of that, i checked the moisture of my wood (we have used up everything dry we had for this year...i'm now on stuff i cut about 9 months ago and split 4 weeks back) and the meter showed 20-25% minimum on the inside of my splits. I think this coming fall, with dry wood and a liner, it will be top notch all the way around!Betting your performance may be a tad better with it hooked to a liner. Did you run the fan a bit yet? Looks like a fan would be a good heat mover in that install. Looks great. Enjoy. Fill everyone in on your burn times etc.
![[Hearth.com] Which brand/size stove?? [Hearth.com] Which brand/size stove??](https://www.hearth.com/talk/data/attachments/196/196907-86e37f3e0af82795896af31ea87c3277.jpg?hash=_B18lmb-_Z)
![[Hearth.com] Which brand/size stove?? [Hearth.com] Which brand/size stove??](https://www.hearth.com/talk/data/attachments/196/196908-7ee1a0e2b3de2b0b99284f641d409774.jpg?hash=qgTgxtBbkx)
That's true...i didn't check every piece. I did find a piece or two in the 15-18% range but they were so rare i just started checking every third or fourth piece. I think with good, dry hardwood...i'll be impressed more than i had hoped!Yes, a clear glass is a good sign. It could be that the average wood moisture reading is lower than 25-28%.
I've burned hemlock in the past. Not the greatest for heat, but ok for shoulder season burning. Just be sure it gets fully seasoned first.
