Hopefully, at some point I will get a chance to see one of these in person. I'll have to take your word for this, but it looks like there is a radius on the corner of the glass and it heads upward right before the screw. Otherwise I agree, running it over a screwhead would make a pressure point.Yeah tricky, right? On our new door (and I believe how it is supposed to be), the glass is still installed over those screws. I think the problem was that the gasket was previously mistakenly running in the wrong place, so that the screws couldn't screw down tightly enough because the gasket was running under them, so then they stuck out more and then they hit the glass. Now the glass gasket runs more to the side of the screws (instead of behind them) which allows the screws to screw down enough to no longer make contact with the glass. Here is a picture of the new door sealed. You can imagine why it took so long to figure all this out!
What is the purpose of this screw and the one above it. I thought it was for the glass clamping bar, but could be totally wrong, never having seen this model Hampton. Covid really reduced my stove shop visits.
![[Hearth.com] Wood Stove Insert with Air Leaks [Hearth.com] Wood Stove Insert with Air Leaks](https://www.hearth.com/talk/data/attachments/302/302412-38b01bdd8ee09bd4969d2cc82ee1573d.jpg?hash=o04KfXDqZn)
![[Hearth.com] Wood Stove Insert with Air Leaks [Hearth.com] Wood Stove Insert with Air Leaks](https://www.hearth.com/talk/data/attachments/302/302382-88982c43ba9d37d7a2cd00f99b9d8c08.jpg)
![[Hearth.com] Wood Stove Insert with Air Leaks [Hearth.com] Wood Stove Insert with Air Leaks](https://www.hearth.com/talk/data/attachments/302/302383-539513e54471c8aff08bc1ab30726d74.jpg)
