Woodstove for interior Alaska cabin
No, I'm not building until at least 2 years from now. This is just early stages of getting basic ideas and rough estimates and slowly putting it together and learn as much as I can before I start contacting different contractors and put pen to paper. This will be a cabin kit and a real estate attorney will be involved. The contractors will be under contract.
How much experience do you have heating with a wood stove? Processing firewood etc?
In the video below, these Alaskans are going to be using coal to heat their home but, look at what they have to do to get that coal back to
their home...
The stove looks like a DS Energy Max 160 stove, the ones you place in a basement or in a garage. He mentions the coal is sub-bituminous stoker coal...
I watch these two and they use coal and wood to heat their garage along with in floor radiant that uses heating oil. They heat their small log cabin with a Blaze King Princess.
Reactions: Highbeam
Yes, they have a very large garage and certain things on their property that I won't have. Do you know how many square feet their cabin is?
I think what you should do, is first have the cabin and its insulation designed.
Then hire someone to do a manual J calculation for the design.
Then design the heating systems.
It's no big deal to change the design of penetrations for piping from wood to coal or oil the other way around. Swapping the design for these is peanuts. Just some different parts and a differently sized hole.
So that can be done last when you know what you are going to need.
And only then does it start to make sense to think about reloading times ("burn times") as a factor in deciding what model of whatever you choose to get - IF you even have the luxury that there are choices to be made in the limited set of heating appliances that fit the BTU need bill.
Reactions: Log Home
Thank you.
I know it's a hypothetical question but, should a duel fuel cabin be something to look into, having two separate heat sources built into one cabin, a coal stove and wood stove in case supply chain issues or price increases ? I think the ability for a cabin to be heated with both wood and coal and switch back and forth gives the homeowner more flexibility and creates a more versatile home.
I think versatility in heating systems is good. But making that versatility more dependent on supply chains, when those are long and expensive, is not ideal.
I do like coal, if you can get it, because storage is ideal, and its energy density is high. It doesn't go bad and doesn't get affected much by ambient moisture. But if you can't get this locally, easily, I'd build a *large* storage where you can store at least 2 years of coal. That way, you're not in a bind when one year coal delivery doesn't work out for whatever reason and you can double down on wood to get through the next winter.
Oil (diesel) is great too, energy density. If you can store it inside. With a double wall and large tank that doesn't get too cold - but only if you can maintain the burner yourself. If midwinter your flue gets damaged by snow sliding down, and you need to rely on oil, but a part conks out, you need to be able to replace stuff yourself.
You'll need a decent stock room with spare parts for important systems at your place. That includes for your heating appliances.
I would hope you make the time to cut and split your wood. Living there and ordering stuff to have it delivered seems antithetical to ... living there. Sure, it's work. But you can enroll family members, make it family time.
Working together to provide for yourself are great times, especially when it's physical work outside.
I would seal and insulate the hell out of that cabin, get two wood stoves, one cat and one tube, and have total control over your heating needs by sourcing your own wood. You'll know exactly how much you have before the winter, and all issues of fuel supply chain and cost are gone.
Off grid Alaska is not a place to live planning to rely on ordering things imo.
Thank you, good info.
I just talked to Hitzer rep on the phone. They have four different stoves available that are compatible with both bituminous coal and wood logs that can be burned in the same stove...
Hitzer 354 HZ-354-CFG
Hitzer 254 HZ-254-CGF
Hitzer 82 UL HZ-82UL-CFG
Hitzer 55 UL HZ-55F-CFG
The two I'm interested in are the Hitzer 354 HZ-354-CFG and Hitzer 82 UL HZ-82UL-CFG. Those are their two biggest stoves. Their two smaller ones that are available are also sold in Alaska and the rep said people there have no problem heating their homes with them either up there.
The rep said you should be able to get 20+ hour burn times with coal. He said he has a farm house that's over 2,400 square feet in Indiana that his coal stove can burn 20+ hours with no problem and keep it warm consistently. The coal stoves will burn longer than wood logs, more sustained heat output.
The Hitzer 50-93 is for anthracite coal only. It will not work with bituminous coal.
The Hitzer's do pretty good with wood logs but, I don't believe they will have as long a burn times as the Blaze King King 40 with logs.
Reactions: Todd
Why are you focusing on the burn times?
Burn time is "# of BTUS into the stove" divided by the BTU release rate per hour.
If you only need the # of BTU per hour of these stoves *at the lowest setting*, you can get the 20+ hrs in the HItzer and the 40 hrs in the BK.
But it's unlikely that you can keep warm with 10,000 BTUs per hour - and that's what a BK delivers when you have it set to a 40 hr burn. That equates to about two 1.5 kW plug in electric heaters...!
So burn times are not something you should be thinking about, as they directly (inversely) correlate to BTU output - and you don't know yet what would be a sufficient BTU output rate.
I predict this project never happens.
Go up to your spot and talk to the neighbors if you are really serious and not just dreaming. That will be the best way to get the info you are seeking, and also find out more things to know about building and living there, and more about what you don't know to ask about living there.
You need to stop focusing so much on long burn times. For example my blaze king princess can easily burn 24 hours on a load of wood but I only do that a few times a year because burning that long it isn't putting out enough btus to heat my house unless it is in the 50s. And that is a 2200 sq ft ranch in the central pa mountains.
Reactions: Log Home and Todd
It’s pretty tiny with no loft just guessing about 600 sq ft. I know they hit -60 a few times and their stove has no problem keeping up.
I wouldn’t poo poo the log cabin idea yet. There are plenty of them doing just fine in Alaska. Once all those logs soak in the heat they stay warm for long time. I would just make sure they are larger diameter D type logs for better R value and they have a good seal between.
Reactions: Log Home
So, top priority first is for the designers/builders to focus on insulation, insulate it as much as possible
Here are some ideas below...
Insulate aggressively: Aim for R-40 walls, R-60 attic, triple-pane windows, argon-filled units with low U-values (<0.20). Consider interior storm windows during winter.
Seal all air leaks with spray foam, gaskets, and weatherstripping. Aim for ≤ 1.0 ACH50 (air changes per hour at 50 pascals) on a blower door test.
Now, is that possible with a log cabin ?
Reactions: Todd
The R value of wood is around 1.25 per inch.
An 8" log will then an R value of 10. That's less than a 2x4 stud wall with 1970s glass fiber insulation...
Moreover, the R10 is across the largest width. The R value of a wall is mostly determined by the heat leaks (just like the R value of a window is determined by the least insulating components). It's like adding the inverse of the thermal conductivity of the different components (scaled by their surface area, I surmise).
So 8" logs would have an R value quite less than 10 because parts will be thinner than 8".
Now, if you put 8" logs and then add R38 rockwool on one or the other side, you'll be good (if you keep the logs sealed).
If you want the log view on the outside, the rockwool would be inside. But then you loose the thermal mass of the logs to even out temperatures in your home. Putting insulation on the outside is better imo.
So, then I'd go with ICF, or proper (offset 2x4s in a 2x6) stud wall with logs slices on the outside as siding. That's what @begreen proposed above.
You have the looks of a log cabin but a much better insulation value.
Also consider the air leakage rating of the windows.
Reactions: Todd and Log Home
R value of wood is dependent on species. You will never get the R values you’re looking for in a true log cabin wall.
You’ll want to be fairly competent with fixing your house too. New houses haven’t been sorted out yet. Plan on multiple systems having issues the first year. People don’t get trouble free new cars, they don’t get trouble free new homes either. And then the unplanned things in life happen like ice falling off the roof and breaking a window. If you’re off grid, there may not be anybody to call to fix it.
In your first post you stated you’ve never owned a home. Are you prepared for this? How are you with small engine repair? What do you do when you’re snowed in and your sled won’t start? Can you trouble shoot it? A contractor will only be building in the summer. This gives you no time to sort out the home and equipment your life depends on.
And guess what they heat water and power their cooking stove with... propane. They also have a wall heater in the cabin, I forget if it's propane or oil but a redundant heat source. "Dual fuel" if you like that term.
The "extra" work involved with them picking up a load of bit coal was self inflicted by trying to be cheap/efficient/frugal. They could have paid to have a dump truck load delivered but that doesn't make a good video!
I also choose extra work with firewood by ordering loads of logs instead of processed firewood. It's all part of the fun. You get to choose just how much of this you want to do yourself and you can hire out most of it.
Do any of you have your wood / coal stove setup so that it's also a water heater like the DS Energy Max 110 / 160 ? How effective are these stoves with heating water through out the house off grid ?
I ask because an option for off grid hot water is the Toyo OM-122DW water heater, it is very fuel efficient, it requires solar power to power it and can be plumbed from a diesel tank. The Toyo heater can be used in the summer when solar is abundant and in the winter rely on the wood/coal stove to heat the water to preserve the battery bank.
These questions are drifting and not hearth specific. Suggest going to a Alaska forum and maybe a prepper forum to get some real world answers specific to extremely cold regions. 8 pages of posts and still no set design requirements for heating. Still circling with coal questions when anthracite is pretty much out of the question.
I would absolutely go with hitzler over ds. And the hot water loop can be plumbed into domestic hot water but it gets complicated
Reactions: Log Home
Sub-bituminous coal is available in Alaska. Having a setup that can use both wood logs and local sub-bituminous coal is a good idea.
Sub-bituminous coal is very abundant and cheap in Alaska. Having a setup that can use both wood logs and local affordable sub-bituminous coal is a good idea.
Again, get local feedback. Fairbanks has strict air quality regs, some of the strictedst in the country due to frequent temperature inversions. Burning brown coal (lignite) is going to be dirty. What does one do when there is a burn ban there? Do some homework.
Coal burning is restricted in Fairbanks, Alaska, particularly in the PM2.5 nonattainment area, where regulations prohibit the installation of new coal-fired heating devices and require the removal of existing ones by December 31, 2024. Only specific types of coal and under certain conditions may be used, following local regulations.
Why are these people burning coal ? Also, there are stoves that burn coal and wood. If coal is banned, just burn wood in the stove...
So yes there are stoves that burn both. But they are all very poor wood stoves
