That's a pretty subjective question with a BK, because the stoves can be dialled very, very low, so each user's minimum setting is based on their wood and their install, not on how low the dial goes.
My minimum setting for keeping the cat active for 24 hours is very low, but it is well above the lowest thermostat setting of the stove. If you pulled my stove out and installed it at somebody else's house, the lowest cat-active setting would not be the same.
I want to burn a load on minimum someday (which will be smoldering the whole load, because the cat will die after 8-12 hours, I'd think), just to see how long it goes.![]()
I know that but I was wondering what or if the stove itself is cooler during a low burn. I know each install is different but if I got a couple people who know what their stove temp is on their low burn it would help me decide if I make the switch. Cause even on your low burn it is lower than what mine can burn at. Right now low burn in mine during shoulder season it is too much for the house unless I load it with only a couple small splits which isn’t a bad thing but it would be nice to just load it all and turn it up if we need it and turn it back down when we don’t.
Just exploring options at the moment.
Lopi Rockport
