As to combustor accumulation. I have been trying to replicate Ashful's experience. First observation, my fire and coal bed is much further away from the combustor than his Ashford. The King is 9" deep.
Nevertheless, I had formed a deep enough coal bed (about 5" deep of solid coals) by burning a load of maple on high. I did this again on low and could not get much in the way of accumulation.
Then, I noticed each time I cleaned out my stove, large amounts of material were going up, onto and through the flame shield. I see the accumulation clearly as the draft pulled particles into the cat.
So, I opened the by pass and that action changed the direction of the particles, greatly reducing accumulation in my cat.
Is this causing others to increase accumulation? Perhaps, but in my King, it was OBVIOUS!
Thank you for looking at this, Chris. At each reload, I use an ash rake to plow the ashes under, and the coals naturally rise to the top. I then rake the coals forward, and load new wood N/S on top. Bypass is open, and plenty of dust gets sucked up the flue during the plowing.
It seems you’re saying that some of this dust is depositing on the flame shield, and then later gets sucked into the cat, when I close the bypass on the next load? It seems this is a possible explanation for the front-side fly ash buildup I’ve been seeing.
It seems to occur most on extended high burn rates, but maybe that’s what it takes to pull ash off the flame shield and into the combustor. I’d think it would happen during that 30 minute high burn we do on every load, but maybe that’s just not enough time for it to occur as completely as it does on these extended burns.
The real bizarre mystery is the back-side build-up in my photo from last Saturday, which might be related, or a completely separate issue. I think Tarzan said he had the same on his Princess cat. That really has me stumped.
![[Hearth.com] 2017-18 Blaze King Performance Thread PART 3 (Everything BK) [Hearth.com] 2017-18 Blaze King Performance Thread PART 3 (Everything BK)](https://www.hearth.com/talk/data/attachments/223/223128-2f6584ca9b1af1126cdb468b64385ac2.jpg?hash=IVS5M1wsor)
