jetsam
There should be one, on the clothes dryers. They suck sooo much air from the house.
It'd be good in on dry days in the summer. It'd be miserable on damp days in the winter.
Just curious if any of you wth these cold draft problems ever notice this cold air when other appliances are running? Like the clothes dryer, range hood, bathroom exhaust. All of which would be removing more cfm than your BK. Not saying an OAK is a bad idea, but very few people ever consider how much air is being sucked out by other appliances. I suppose offsetting with an air supply to the stove is about the best one can do in most cases.
No, I have'nt, but then again those things you mentioned are'nt drawing air/vacuum 24/7..Just curious if any of you wth these cold draft problems ever notice this cold air when other appliances are running? Like the clothes dryer, range hood, bathroom exhaust. All of which would be removing more cfm than your BK. Not saying an OAK is a bad idea, but very few people ever consider how much air is being sucked out by other appliances. I suppose offsetting with an air supply to the stove is about the best one can do in most cases.
You must not have kids at home then!No, I have'nt, but then again those things you mentioned are'nt drawing air/vacuum 24/7..
Honestly, I did'nt really notice the cold draws the 1st. Two years of having this stove installed, but the last two winters were pretty mild..
This year it's been damn cold, for long periods of time !!
Thank goodness some progress is being made on the 30 box.
Definitely not a 30 box only issue. Lets get a link to the new gasket listed here. Cant wait to try one.
@Ashful ... any updates on the fly ash situation? Its warmed up some, have you noticed a weaker draft, or maybe burning with t-stat down some slow things down? Just curious.
Does it feel like there's much air/heat blowing out on low? "Longest" and "hottest" burns are opposite; The hotter you burn the stove (the more open the air is,) the shorter the burn is going to be. Now, I suppose the higher you have the blower, the more heat you are going to pull off the stove, and less will be going out the stack. I wouldn't be too concerned about that, as long as my house was warm..that's the bottom line.
New install two months ago, replaced an Enviro Kodiak 1700. Haven't really had a chance to test the BK out in cold temp until this last week. 10, 10, and 12 df the last three mornings with highs around 30 here in central WA. The insert is heating the house (1700 sq ft) very well with floor fans moving the air.
I want to run the stove fan as low as possible to get the longest, hottest burns. Is the fan really moving any air at the lowest settings? Or do you think the fan needs to be at least 1/4 speed to not lose the heat up the chimney?
Just got home to check it out. It's not as smooth looking as yours in the picture. I hope it works outThis is probably high density with a separate inner core and outer braid - make sure he offsets the the joint of the inner core from the outer braid and doesn't just butt the two together...
AND make that joint as smooth as possible...
