I really would like to have OAKs, but having seen the extreme trouble the Verizon crews (yes, plural... they had to send out multiple crews over the course of one very long day) had with drilling a simple 1” hole thru my wall for a fiber, I don’t see it happening. Rubble-filled mud stacked stone walls are best left as they were built, I suspect.
I just talked to a guy at ProCut about your situation, he said it'd be no problem to drill that foundation, but it's out of their area, and they mostly do commercial work..This is wandering a bit from the BK subject, but the excursion is likely short enough to slide. I assume you’d drill from inside to out at the desired center line with a 1/2” hammer drill, so you have a reference point, and then drill from outside to in with the core drill? I couldn’t imagine the mess of running a core drill inside the house.
Also, the core bits I’ve seen are usually very shallow, and I’m going thru 24’ish inches of stone. Can they be purchased in that depth, such that you can core drill thru, and then push back out with the pipe to be inserted? If withdrawing a core drill without a pipe follower, rubble will likely instantly begin shifting.
The last hole i drilled was through 4' of foundation. I could only find a 36" bit so i had to clean out part way and use an extensionThis is wandering a bit from the BK subject, but the excursion is likely short enough to slide. I assume you’d drill from inside to out at the desired center line with a 1/2” hammer drill, so you have a reference point, and then drill from outside to in with the core drill? I couldn’t imagine the mess of running a core drill inside the house.
No all points he mentioned are known issues with oaks. Which is why i dont just install them for every stove. That and they are difficult to install properly for basement stovesGood thoughts, Blazing. But these OAKs have been standard hardware for years, if some of these concerns you highlight were of substantial merit, they’d have likely addressed them by now.
On room air dryness, yes... my house runs 15% - 25% RH all winter long. I have convinced myself that running two stoves 24/7 is contributing to that, by constantly expelling my humidified (via our bodies, showering, and cooking) air and bringing in fresh air to be heated and dried, but I have not made any measurements that actually prove this.
If it was easier to do i would absolutly say try it. If it was me i would try to find an easier way to hook up a temp oak to see if it helps any.Thanks guys, esp. for the call, showrguy.
@bholler, are you in favor or against the idea of an OAK in my situation? If on the fence, what would you do to evaluate the merit of having one? I have no problem with draft, even running both stoves + dryer + range hood + bathroom vents. My sole interest is improving overall efficiency and humidity situation.
A very Wise Man once spoke about this>..>........... See post #1421..If it was easier to do i would absolutly say try it. If it was me i would try to find an easier way to hook up a temp oak to see if it helps any.
Hah... and we've come full circle. This will not be fun, building sealed adaptors for two windows and running flex duct from each stove, out of the fireplace, across the room, and to the closest window. One will cross my daughter's play area, the other my wife's desk, on the way to their respective windows. But I'll do it!A very Wise Man once spoke about this>..>........... See post #1421..
Yes they sell an adaptor that positively attaches to the stove.Hah... and we've come full circle. This will not be fun, building sealed adaptors for two windows and running flex duct from each stove, out of the fireplace, across the room, and to the closest window. One will cross my daughter's play area, the other my wife's desk, on the way to their respective windows. But I'll do it!
I assume BK sells an adaptor for the stove connection?
I wouldn't use heat as the measurement, I would use relative humidity as the measurement to see if its working, you should have more humidity in the house since the stoves make up air is now dedicated with the oak., I’ve been wondering for a long time if I’d have better heat retention running an oak
169$ + tax for the air kit in Montreal Canada... All I need is the Ashford air intake plate and 2 feet of flexible STainless steel pipe
Pretty sure I can custom fab one for mine this summer for quite a bit less than $170 quid.Aluminum vent should do the trick I agree. For the plate I either find a dealer who’s ready to order me one or I will figure out something
Bedrooms on the second floor can run pretty cool, when it gets cold out.
