Best Way to Make Protruding Bricks Flush with Hearth?
cowtown Posted By cowtown, Sep 24, 2011 at 11:50 AM
Thread Status:
  1. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    I have the fireplace guy coming this Wednesday to take some measurements so that he can firm up a quote.
    If I get the okay from him and we are able to agree on a deal, I need to make the proturding bricks at my fireplace opening flush with the rest of the brick wall (see pics) - any suggestions?
    I was thinking of simply going to a big box store and renting a tool (not sure which one) and then performing the cuts, any idea on what tool I should be asking for - perhaps an angle grinder?
    Thanks in advance for any suggestions.
    Stop hovering to collapse... Click to collapse... Hover to expand... Click to expand...
  2. madison
    madison
    Minister of Fire 2.
    NULL
    Sep 12, 2008
    1,566
    126
    Loc:
    41.33°N 74.18°W and 44.67°N 111.0°W
    the exisiting hearth stone in front of the brick looks sorta on the shy side I would indeed make sure it is to code prior to demo. Otherwise, a hammer and chisel for the brick?
  3. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    Yes, I will need a hearth extension - that is in the plans.
  4. fishingpol
    fishingpol
    Minister of Fire 2.
    NULL
    Jul 13, 2010
    2,049
    1,130
    Loc:
    Merrimack Valley, MA
    When the bricks are cut flush, are you refacing over them? Are you putting in an insert with a surround? Cut bricks will not look as nice as the regular uncut sides. If you are putting in an insert, check that by removing the protruding bricks you will still have the required depth. A surround kit should cover the newly exposed cuts.
    As far as tool, angle grinder with diamond wheel should work.
  5. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    That is what I was thinking, angle grinder witha diamond wheel.
    The surround just covers the cut brick.
    It is a deep firebox and will hold the insert - I will not start demo until after the guy comes on wed.
    Thanks.
  6. wood-fan-atic
    wood-fan-atic
    New Member 2.
    NULL
    Oct 4, 2010
    870
    6
    Loc:
    Long Island, NY
    You could rent a chipping gun - I like the Bosch SDS Plus. It is not as heavy as the larger models, is both a chipping gun and a hammer drill, and is strong enough to shave those bricks just shy of flush with ease.
  7. certified106
    certified106
    Minister of Fire 2.
    NULL
    Oct 22, 2010
    1,472
    235
    Loc:
    Athens, Ohio
    +1 on that idea! I have used them alot and it will not make nearly as much dust or mess as the angle grinder
  8. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    The chipping gun - would the cut not be as flush as the angle grinder (I know the angle grinder will kick up a ton of dust, but I can prepare for that).
  9. certified106
    certified106
    Minister of Fire 2.
    NULL
    Oct 22, 2010
    1,472
    235
    Loc:
    Athens, Ohio
    You would be surprised at how flat you can get them with a rotary hammer once you get used to using it. I figured the surround would cover the cut brick so it wouldn't be to important if they looked perfect.
  10. madison
    madison
    Minister of Fire 2.
    NULL
    Sep 12, 2008
    1,566
    126
    Loc:
    Don't forget to research the mantle clearances as well as the hearth. I would not skimp on the hearth dimension with all the nice carpets and floors. It is amazing how stuff can fly when it is raised up off the floor.
    BTW really good looking cabinetry.
  11. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    The guy is coming Wed to measure, I will need a hearth extension, I know that already; hence, I will pull the carpet back to accomidate it.
    The hearth to the mantle is 37 9/16", the exact clearance needed for the Alderlea T5 insert, we will see how it goes Wednesday.
  12. wood-fan-atic
    wood-fan-atic
    New Member 2.
    NULL
    Oct 4, 2010
    870
    6
    Loc:
    Long Island, NY
    The chipping gun is light enough and powerful enough to be very precise, actually. You will have no problem chopping those bricks within 1/4" - 3/8" of the flat face of the hearth. The insert surround will cover any imperfections.....I had to expand my fireplace opening,too, and that is what I used. Very little mess,also. Use the small spade bit with a nice edge on it.
  13. jatoxico
    jatoxico
    Minister of Fire 2.
    NULL
    Aug 8, 2011
    4,067
    1,354
    Loc:
    Long Island NY
    Brick is soft. If the surround will cover it use a masons hammer. If it's going to show the you'll have to go with something more precise.
  14. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    I am right on where it might/might now show, so I think I am going to use an angle grinder with a diamond blade.
  15. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    Just go my first quote from a Mason - yea, $900 plus tax to cut the brick, are you kidding me?
    Anyhow, for that price it looks like I am going to do it myself.
  16. jatoxico
    jatoxico
    Minister of Fire 2.
    NULL
    Aug 8, 2011
    4,067
    1,354
    Loc:
    Long Island NY
    Osillating multi tool would give very precise cut. Does not chip at brick, cuts it.
  17. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    I was thinking the same thing, not sure if the blade woudl get all the way through the brick though.
  18. jatoxico
    jatoxico
    Minister of Fire 2.
    NULL
    Aug 8, 2011
    4,067
    1,354
    Loc:
    Long Island NY
    Once the doors are off looks like you have good access. Sounds like you only need to make a small clean edge (1" or so). $900 saved should provide sufficient motivation, that sounds like a lot of $ unless the lintel is in the way or something.
  19. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    Will make a go of it - my guy is coming Wed to measure to make sure a T5 will fit the space, once I get the okay, I will provide pictures of the demo (well, only if it goes well ;) )
  20. jatoxico
    jatoxico
    Minister of Fire 2.
    NULL
    Aug 8, 2011
    4,067
    1,354
    Loc:
    Long Island NY
    Nice, I'll be looking for pics.
  21. Dune
    Dune
    Minister of Fire 2.
    NULL
    Jan 14, 2008
    3,137
    277
    Loc:
    Commonwealth Of Massachussetts
    I wouldn't use an angle grinder to cut brick in that house. Buy a brick chisel and drill hammer.(short handled 3# hand hammer) The cleanup alone would be monumental.
  22. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    I was thinking of this as well. I have the brick chisel and a drill hammer.
    I think first I will go with the oscilating tool with the grout removal attachement. Go brick by brick taking as much mortor and cutting as much brick as the grout remval attachement will let me. I can have my wife hold the shop-vac and suck up any dust as it comes out. Then when i have cut as much as I can, finished it off with a brick chisel.
    For deeper spots, use a hammer drill with a masonry drill bit.
    I think the angle grinder will be the tool of last resort (kind of like a nuclear bomb).
  23. jatoxico
    jatoxico
    Minister of Fire 2.
    NULL
    Aug 8, 2011
    4,067
    1,354
    Loc:
    Long Island NY
    There are brick and masonry blades for multi tools
    A lot less dust than a rotary grinder
  24. cowtown
    cowtown
    Member 2.
    NULL
    Sep 10, 2011
    148
    0
    Loc:
    Alberta Canada
    I did not know this - I will take a look into it, thanks.
  25. ScotO
    ScotO
    Guest 2.
    NULL
    give a bricker hammer and 4" brick chisel a try...you will be surprised how easily AND precisely it will cut those bricks......and if any of them do show, they will look more natural than a cutting tool will afford.....trust me I do a lot of natural stone masonry/veneer and with just a little practice you will be cuttin those bricks with a chisel and hammer like a pro....if you have access to some spare bricks you can practice outside on them...to get a feel for how to cut them...usually a couple of medium hits on each cut will do the trick.....keep us posted on how you make out!
Thread Status:
