continuing to learn and need more help
k0wtz
196
missouri
I now have the Vermont Castings Stardance stove working correctly. The logs are now set up and we have a nice flame across the logs.
But the fans make a whistling noise I can throttle the fans down but then it sort of defeats the purpose of the fans.
V/C runs 2 fans together at the bottom of the stove for the blowers. I dont think this is an uncommon method for free standing stoves.
anyone encountered this noise thing and have a solution?
thanks
I never encountered THAT noise ----I'm a retired gas fireplace repairman. But I've encountered plenty of noisy fans, which is why I'm agin 'em.
Can you get the outfit that sold you the stove to repair it?
Reactions: k0wtz
I bought the stove used mom working... I can't figure out the whistling noise... May have to live with it but next step to take them off and oil them but it's sort of a whining noise!!!
Fans in gas fireplaces can be quite difficult to get out to repair or replace.
Personally I'd just use a box fan if that's your only source of heat and you need to break up hot and cold layers. If you also operate a central heating system that ought to do that job for you without the assistance of the gas fireplace.
Take a careful look at the fan before you start, and decide if it's worth the trouble getting it out.
And if it looks like a job getting it out, I'd order a new one from the manufacturer (to be reasonably confident it will fit) rather than oiling it up when it can easily cause more problems.
