Hi everyone,
I’m looking for advice on choosing a wood stove for my 1500 sqft home near Port Townsend, WA (climate zone 8b-9a w/ lows 15-25°F).
Thank you so much!
Home Details:
- Two stories -- two small bedrooms and a bathroom upstairs.
- Chimney is centrally located and has been cleared by a chimney expert.
- Built in 1982, the insulation is decent, but the house breathes well due to cedar board and batten siding.
- Stove will be located in the living room (12'x14' w/ 8' ceilings) which connects to a kitchen and great room (14'x24' w/ 12' ceilings), lots of large south-facing windows.
- Far side of house has laundry, bathroom, and another bedroom.
Usage:
We plan to use the stove for daily heating. We might install mini splits in the future, but not for a few seasons. I have access to seasoned firewood, but I’m concerned that Blaze King models might be more particular and picky. I also understand it's a learning curve and I'd eventually be fine.Stoves I'm Considering:
- Woodstock Palladian or Keystone: Concerned it may be too small (rated for 1300 sqft) and need frequent reloading
- Woodstock Fireview: Seems like a good size; unsure about ease of use (no ash pan?)
- Blaze King Ashford 20: Promising option. I like the cast iron. Would the 30 be overkill?
- Blaze King Princess: Worried it might be too large and overheat my space. Love the idea of long burns tho.
Questions and Concerns:
- What size should I be looking at amongst these? Any other stoves in particular that I should be considering?
- I understand that it’s generally better to load the firebox and run the stove hot. Does this mean I should steer clear of the larger models (BK Ashford 30 and Princess ) as they'll heat me out of the house, or do those larger fireboxes simply mean that I'm going to get longer burns once I turn the stove down and am running off the catalytic system?
- I'm curious about lived experience with the difference between having a Woodstock w/ soapstone and thermal mass for extended heat release versus the longer burn times with the Blaze King stoves.
Thank you so much!
![[Hearth.com] Help Needed: Wood Stove Choice for 1500sqft in Port Townsend, WA [Hearth.com] Help Needed: Wood Stove Choice for 1500sqft in Port Townsend, WA](https://www.hearth.com/talk/data/attachments/330/330286-d47413c25e8b746e5d95e96a393e77fd.jpg?hash=ZJw5rwvJr2)
![[Hearth.com] Help Needed: Wood Stove Choice for 1500sqft in Port Townsend, WA [Hearth.com] Help Needed: Wood Stove Choice for 1500sqft in Port Townsend, WA](https://www.hearth.com/talk/data/attachments/330/330305-2c1773fd84367e6ca3835c1aa494b38c.jpg?hash=cD9iaTbF79)
