I owned an IH Cub 123 for several years, 1965'ish model. Stout little tractor, with a rear end the size of a pickup truck, but any machine that old is not going to be the most reliable option in the hands of most home-owners.Do yourself a favor and buy one of the old IH cub cadets. Kohler motors, steel frame, cast iron front axle. All steel body, Bullet proof tractor.
My 30 year old cub will run circles around most any new tractor you can find.
The Cub Cadet, Craftsman, Yard Man , Lawn Chief and some others are all made by MTD. My friend got the Cub Cadet 46" XT1 Kohler Enduro and I have the Craftsman Pro Series 46" with the 24hp Kohler. They are virtually identical machines except for the color scheme. That said, if you have a good Cub Cadet dealer I would go with them for better parts and service.Looking at a Cub Cadet LT50FAB to replace pos I bought from Sears 4 years ago.
Seems every brand I look at has this hydro xmsn. Shouldn't be an issue since I'm only doing a flat acre once a week.(right?) Wouldn't be used for anything else since I have a Gator.
Yes it's a very common transmission in many lawn tractors that are below the "pain" threshold ($). If that's all you're going to use it for it would probably be fine. Making sure that the cooling fins on the transmission stay clean and not clogged with grass will help prolong it's life. What kind of lifespan are you hoping to get out of it?
So 20 years then, at the least??I'm 75, til I croak
You can't beat those old machines, but I have to take issue with the terminology you use to describe your sentiment. Specifically, it is the LACK of engineering that made them so great, so many of the key drive components are massively over-built. "Engineering" is the art of "just good enough", at lowest possible cost, not throwing money down the drain to overbuild one part of a system when other components are guaranteed to fail. The beauty of it is that those with the time and energy can keep these old tanks going, despite their shortcomings in some areas, thanks to being so stout in others.I'm in NJ too. I would by an older 30+ year old deere. maybe 318 in great condition. I would expect to do some repairs occasionally. I however I am continually amazed with the engineering that went into these small tractors back then. I currently have a deere 420 for sale. The 420 is way over kill for you. Its built like a tank. Its from 1984. Great machine.
