SpaceBus
The magnet wouldn't damage the chain or cutters. The saw will throw the magnet if it comes into contact with the chain. It happened to me with an attachment for my mill.
I’m not keen on the idea of something hanging off the side of my saw. I often cut up to finish a cut after I’ve rolled a log. This puts the tip in the wood. I’m also in big rounds at times that eats the whole bar up so can’t have anything hanging off the bar. And really a +\- of an inch is no big deal. After years of cutting I can pretty much hit the 16-18 mark just by site. I still measure with my sharpie marks now and again to keep my eyes calibrated.
You could probably cut the curved part off the hook end, cut threads on the straight shank, use a nut and washer to put a t pvc cap onto the magnet/shank, glue in a long piece of pvc pipe and cut to length.
I like the magnet idea. Just hook it onto bar, make your marking cuts, then remove it, and buck the tree up. But the cost.....too much. Could one be made? I saw this magnetic hook set at Harbor Freight (4 pack/$3+) and bought one. Cut the bend in hook off and drill and glue a piece of rod into post(?). It should work.
I'll have to check it out, but seems like it would be better suited for shorter length cuts.I had the same question, so I searched the site for zip tie. It's a good idea!
Use a longer zip tie, but you would be surprised at how far it will be between the bar and the tip of the shorter zip ties. The handle sticks out pretty far from the bar.I'll have to check it out, but seems like it would be better suited for shorter length cuts.
I used a long zip tie and trimmed it down to the length I desired.I'll have to check it out, but seems like it would be better suited for shorter length cuts.
I use this all of the time...it works very well...never any issues with it...I also have the Mingo paint marker but only use it when I have multiple logs drug out ...one tip would to be to paint it orange...it blends in well in the woods and can be lost....ask me how I know....lolI've used different methods for marking up logs before cutting into consistent lengths, but those methods proved to be time consuming and not very accurate. Until now:
ACC-U-MARK FIREWOOD MARKING TOOLS
Pro-quality firewood marking tools for professionals and DIY firewood producers. Instant on/off, no tools, simple and accurate. Made in Montana.acc-u-mark.com
It came today, and I was able to use it a little. It's extremely well crafted, light weight, simple and easy to use. Not only do I get the correct lenth of wood, but it also helps me to start a square cut as well. I highly recommend this tool
Good stuff. I presume the arrow/bolt had the insert in the end that the tip/broadhead would have screwed into?I made my own version. Took me all of 5 minutes. The magnet came from Home Depot for $5. The arrow is an old aluminum crossbow arrow. There is a 1" 8-32 screw holding it together. (Leftover screw from a cabinet handle). Finished it measures 20.5". My Furnace takes 21" max, so I'll probably cut a little off.
View attachment 268858 View attachment 268859
Yes. It also doubles as a beautiful hood ornament for my tractor when not in use! (My JD 2010 may be a piece of junk but at least the hood is metal!)Good stuff. I presume the arrow/bolt had the insert in the end that the tip/broadhead would have screwed into?
We all know how nice your stacks look.Because of how I stack, I prefer my rounds to be as close to 16" as possible.
