Hmmm.. with the slightest of guess and a small chance you might be having an issue with the t stat either not set to open fully or the stone veneer installed is reflecting / pooling heat and causing the even requested fully open t stat to close partially (getting fooled thinking the stove body is hot enough) what the clearance from the back of the stove to the closest part of the stone work?No visible smoke in the house at all when the door is opened. I’ve had draft issues in other houses and this does not seem to have a problem with draft at all.
![[Hearth.com] Max heat [Hearth.com] Max heat](https://www.hearth.com/talk/data/attachments/302/302280-dfc8a2d49f3d5c6e3d31d9df2c319e71.jpg?hash=KvVtD2hkjc)
![[Hearth.com] Max heat [Hearth.com] Max heat](https://www.hearth.com/talk/data/attachments/302/302282-233dc5b253e98e6c2494490ae230b0f3.jpg?hash=JFO_nSB_97)
