Ok so today I started the T5 at 9:30 am and after the kindling and 2 small splits burned down to coals at 10:30-11 I loaded it up 7-8 splits about 3"-4" diameter got it going about 5-7 min and turned down the air all the way. Now its and the stove top go's up to 750* -775* according to my new Fluke IR thermometer and then begins to slowly drop.
by 1:30 2 hours later no flames plenty of coals but the stove top is at 400 ok so I load her up again this time it took 2hr 30 min to get back to 400*
ok so I thought maybe the wood is too small at 3:15 I stuffed 3 large splits in (almost didn't fit) let them go for about 5 min turn the air all the way down stove top took longer to get to 750* but by 6:00 I was back at 400* on the stove top and looking to reload again.
I loaded her up again at 6:00 and by 9:00 the stove top was 350*
Should I be able to keep the temp between 500* - 700* with the air down all the way? Am I just being impatient should I let the stove top temp go down to 250 - 300 before reload. if this is normal somehow I miss understood all the posts about burn times I was expecting to get 6-10hrs between reloads with out the stovetop going below 400*
I checked the door with a dollar bill and the gasket seems ok I am going to call PE and see if they have any ideas on Monday but I thought you guys might have some suggestions of thing I could try tomorrow.
