Thank you for the response, I'll look into leaving a gap. The house was built in 2010. I came to the need for outside air by the fact that the house is spray foamed in the walls with plastic under the blow in insulation in the ceiling, and despite the HRV and bathroom exhaust fans we struggle to get humidity out in the winter (tough to get humidity below 60%). I don't want to run into draft issues while running a dryer and bathroom exhaust fan for a shower. More than any, I shy away from the idea of pulling cold air into the home through a gap elsewhere, and thus cooling it, to facilitate a draft. Pulling outside air directly into the stove for combustion and out the chimney without entering the home seems ideal, but again I'm new to wood heat.
I can only answer part of this. Spray foam insulation is pretty good stuff. It is expensive, but the install is fairly flexible. Do you know the R value of your walls and ceiling? Somebody somewhere -hopefully- ran an "air door" test or similar as part of getting the HRV set up correctly.
I don't actually own an HRV, but my next house more than likely will have one, I have been reading up. For an air door test the operator should block all the architectural openings, windows, bathroom fan vents, HRV intakes and outlets etc, and then set up a vacuum pump - usually on the front door - and try to pull a vacuum on the house. Somewhere on the report should be a line more or less "Your house is leaky. If it had been built perfectly air tight you could make a hole in the wall ____ square inches to approximate how leaky this piece of junk you put a mortgage on is."
Or words to that effect. I hope the numbers have gotten better. Last time I read up on it, a 100 sqin equivalent leak was considered excellent, once a home got up into the 400-500 sqin equivalent range the homeowner had some work to do. I just can't imagine a hole in the wall of the living room 10x 40 inches, it is an astounding amount of heat loss.
I do struggle to keep my indoor humidity at 10% RH in the winter, and the wife wants hardwood flooring. I frequently see 70%RH in the summer. Is 60% RH in the winter really a problem for you, and why?
Ideally, with an HRV system you would set the wood stove up with an OAK so the combustion air for the stove isn't coming through the HRV filters. If the drywall isn't up yet, you can run an output leg over to near the stove, but you are signing up for more frequent filter maintenance on the HRV filters if you do that.
One option. if you are running the HRV for pollen abatement would be to put a valved air inlet near the stove (above grade), heat with electricity until you have snow cover, then open the valve and run the wood stove. There is a pretty good option for that, available in 80 and 120cfm ratings, but i am striking out. Jiffy 80, Jumbo 120, dunno, my google-fu is off this week.
Could you maybe put the stove somewhere else in the house where an OAK is better suited?
At my current home, I have the upstairs sealed up pretty tight and I heat it with supplemental wood. I do have some air leaks downstairs, I let the combustion air come in through those holes and just go with it.
![[Hearth.com] Realistic savings and fuel value? [Hearth.com] Realistic savings and fuel value?](https://www.hearth.com/talk/data/attachments/229/229239-83340f1fd111fb316c99a885cbea107d.jpg?hash=u4pv_R6Mjp)
![[Hearth.com] Realistic savings and fuel value? [Hearth.com] Realistic savings and fuel value?](https://www.hearth.com/talk/data/attachments/229/229240-95a03169f2199b04affc85d461a02a31.jpg?hash=_Ec8-rVKMl)
