I had a Regency i2450 installed last week. Today when the wind kicked up, it produced a harmonic sound similar to blowing across the top of a bottle. The sound stops if I open the draft control. It seems the i2400 had a similar problem that people corrected by placing aluminum tape over the minimum air inlet and punching a hole in it so the edges were ragged or by placing a ring magnet around the inlet. That secondary intake on the i2400 is located on the side opposite of the draft control rod and can be accessed by removing the blower. Unfortunately, it's not in the same location on the i2450.
Does anyone know where it is located? The instruction manual indicates "the I2450M unit has a secondary draft system..." but doesn't say where it is. Thanks!
