								![[Hearth.com] Vermont Castings Aspen C3 2022 [Hearth.com] Vermont Castings Aspen C3 2022](https://www.hearth.com/talk/data/attachments/332/332746-bb740f788fe260421554f9a1169efbbe.jpg?hash=B157ASxs7f)
This oak is probably 2-3 years covered. A lot of the oak got split just enough to get it off the side of the road, turns out it’s kinda handy to get this little stove to run longer.I wish I had a stash of oak like that.
Yes, something is odd with the time stamp. I saw your post at 7:45pm PST here which should have been a 3 hr time difference to EST or 10:45pm. That's what confused me. But if the shot was taken an hour earlier than the posting that would make sense.Just took me a while to get from the “wood shed” to my old VC Aspen thread.
9:45EST, but since we are on this. I started posting my own time stamp as above since the forum will post the time at first, but then just switch to the day.
It’s in the screenshot above, it has the time. Come back tomorrow or next year, and it will just give the date. I noticed this last year when I went to look back at my starlogs and the realized half my data had been replaced with a date rather than than a time. I lost half my records of burn times. So, now I just post my own timestamp in my the posts.
266 flue, 360 STT, 6” of hot coals. Cracked the door, I’ll see what can burn down and scoop it out when the house starts to get noticeably cooler.
11:20pm
I let the stove burn down more than normal because I had a high pile of coals. STT got down to 275 and house is 65. Outside temp is
I could have reloaded earlier and kept the house temps up, but I wanted to burn the coals down a bit, and prolong the overnight burn. Let’s see what happened in the A.M.
Flue and STT respectively. Rear air control is all but closed. Let’s just call it closed. I can maybe press it 1/16-1/32” before it bottoms out.
It may be worth specifying that this is on cool down, med/light coaling, ready for a reload for the evening then another before bed.
Is there any way to just manually open up the air flap to burn down the coals when you need too? I think it would drive me crazy not to have any control over the air.
Sometimes I literally crack the door, sometimes I wedge a pencil in the intake to keep it open.
You would have to blow air into the OAK opening and get it to run up the back of the stove behind the shield to the coil that is attached to the back of the probe just below the flue collar.could a small fan help cool the area of the stove where the spring is?
Re engineering a stove is hard. Refresh my memory, Do you have a damper.You would have to blow air into the OAK opening and get it to run up the back of the stove behind the shield to the coil that is attached to the back of the probe just below the flue collar.
Pictured is the probe that sticks through the back wall. The spring is on the back of it.
If I keep tightening the chain to raise the opening temperature, the flap will will be fully opened and unable to move farther as the spring cools.
Say I took another 2 links out (compare it to a ceiling fan pull chain) maybe 1/4”, as the spring cools the flap would hit the full open position and be stopping the bimetal spring from retracting that last 1/4” into the room temperature position. I don’t know if holding tension on the spring and not letting it find its natural position would cause it to fail.
I did add one a year or two ago that I rarely use. Sometimes I would get a load that was a little hot, but I found I prefer using the intake damper I made over the chimney damper. Technically I could disable the flap and use a combination of the home made intake damper and a flue damper and run it like a pre-EPA stove, but that hats not really what I want to do either.Re engineering a stove is hard. Refresh my memory, Do you have a damper.
The BK fund is where to put your efforts. I do think your are trying to squeeze the last 5% out of that stove that seems to be working well will be a challenge.I did add one a year or two ago that I rarely use. Sometimes I would get a load that was a little hot, but I found I prefer using the intake damper I made over the chimney damper. Technically I could disable the flap and use a combination of the home made intake damper and a flue damper and run it like a pre-EPA stove, but that hats not really what I want to do either.
Like I said earlier too, it’s completely manageable with rotating in some pine, so it’s really just nuisance at this point, and the need to keep enough pine on hand to accomplish the coal burning. An outcome of +\- 1 hr of heat between reloads isn’t going to be a game changer for anyone. In fact, the heat isn’t better if you do burn the pine vs trying to introduce enough air for coals. In fact, it holds coals so well that I can almost always relight within 2 days without a match, just take the coals back up to the top and blow a little life into them.
So, in reality, I should quit feeling like something got left on the table, because that little stove does good and is probably doing about all a sub-2cu ft stove can do, but the tinker in me sees meat on the bone yet.
That tinker wants to adjust the chain, or add a factory looking linkage rod that runs just under the stove that will slide the flap, or I can just go cut another pine and put $20 more in the BK fund.
