weatherguy
My ash is usually ready after a full summer if cut and split around April, sugar maple is good wood but it takes me two full summers.
Good to know. I will try to find a way to use the tarps in a way that doesn't cover the sides or, like you said, let it season a bit before covering. The tarps are only held by the end grommets, so there is wind flow under them as I have to occasionally pull the middle part back over the stacks when they get blown off.
Could it be this wood has "bacterial Wetwood"? Will it ever season? Should I keep harvesting wood from the tops?
The smell when splitting perhaps should have given it away. No one else around me has to season Ash for more than 8 months and I am almost a year beyond that.
I haven't seen a definitive answer to that. No literature I've seen (that I can find) points to that. There is plenty of circumstantial - stuff won't dry because of - but the subject always changes to something else, and that question always gets sidestepped. Can a fungal or bacterial disease inhibit the seasoning process? The only time I've heard it mentioned is in the book you may have referenced, and there again, his explanation was circumstantial, info from the native folks saying so. Still leaves me wondering too.Can a fungal or bacterial disease inhibit the seasoning process?
Yes, that section of book is what put the idea in my head as I have never heard of wood that won't season, unless it was rotten or punky. My wood is neither.I haven't seen a definitive answer to that. No literature I've seen (that I can find) points to that. There is plenty of circumstantial - stuff won't dry because of - but the subject always changes to something else, and that question always gets sidestepped. Can a fungal or bacterial disease inhibit the seasoning process? The only time I've heard it mentioned is in the book you may have referenced, and there again, his explanation was circumstantial, info from the native folks saying so. Still leaves me wondering too.
No, I don't think they are too big and the hissing is not confined to large pieces. Some of the small ones hiss too.all wood i was told will dry in time
are the pcs of wood to big
I might try that if my stacks weren't in the woods..Keep the tarps off green wood for at least 2 summers.
Stacks in the woods unfortunately sounds hopeless to me for prime weathering (my new term for "seasoning")I might try that if my stacks weren't in the woods..
Glad to hear you can get it done in the woods....i guess im just spoiled i have a 2 acre field to stack and stage......not sure i would bother processing my own firewood if i had to stack in the woods.....i feel direct sunlight is more important than wind to weather cordwood properly....No problem getting wood dry, but it's not as fast as in an open, breezy spot. The problem with not covering in the trees is that leaves and catkins pack into the tops of the stacks.
I think that the fact that I can get my wood to 18 or even 16% confirms that the sun isn't the prime ingredient.i feel direct sunlight is more important than wind to weather cordwood properly....
Anything standing dead, if cut in summer, for me is ready in 2 months....2 years in the woods would make sense.....the woods that border my property is mostly damp swampy lowlands so it wouldn't be an option for me....goes to show everyone's situation is somewhat uniqueI think that the fact that I can get my wood to 18 or even 16% confirms that the sun isn't the prime ingredient.
I only tried one stack in the open, on top of a windy ridge. It was some dead Red Elm that ended up that dry, but in only two years, and I think it would have worked with dead Red Oak as well. Average size splits for me are 4-6".
I've cut Red Oak that had been standing dead for several years, that still had 30%+ moisture in the trunk. Maybe your non-cat will work OK on higher MC wood than my cat stove will. I need 18% wood for easy stove operation. I don't know if you even bother with a moisture meter, and what moisture content your two-month wood would have..?Anything standing dead, if cut in summer, for me is ready in 2 months
A few things....i do not search out 20-30" oak if im looking for standing dead....im looking for basically barkless, limbless telephone pole trees....maple, ash, beech and hickory (maple being fastest....ash the slowest)...so if i whack that 8" trunk round in half....its good to go in 2 months. 30% moisture or 50%....doesnt matter.....water evaporates much more quickly from standing dead or even from a 4 year weathered stack of oak.....think of standing dead (8-10" dia. trees) as a sponge at 30% moisture and freshly split green cordwood as a potato at 30%.....guess which one drys faster out in the summer sun....obviously the sponge......my clean glass, clean liner i clean once every 2 years and 35 years of processing cordwood is my "go... no go..." for picking out my weathered wood for the winter......i do have a meter and only use it on the rare red oak i come across....but even now I know not to touch it for 3 summers.....4 being better.I've cut Red Oak that had been standing dead for several years, that still had 30%+ moisture in the trunk. Maybe your non-cat will work OK on higher MC wood than my cat stove will. I need 18% wood for easy stove operation. I don't know if you even bother with a moisture meter, and what moisture content your two-month wood would have..?
I hope that's the case on some dead-standing (four years or more) White Ash I stacked for my SIL a month or so back; It was 30% in the trunk and I was taken aback by those high readings, given the length of time it had been dead. If that stuff can get dry over the summer, I'll be thrilled. It's three rows deep on some pallets, so I don't know......water evaporates much more quickly from standing dead
With the tarp hanging 12" over, right on top of the top row, you are likely catching evaporation and keeping it dripping on to the stacks. I've found, In a climate that is probably much like yours, that I have a similar problem with wood drying.I have a mix of sugar maple and Ash that has been cut, split, stacked for 18 months. Wood had been stacked in a single row and off the ground on old fence rails. Plenty of wind and sun. Wood has been top covered only with tarp. Tarp hangs down the side about 12 inches.
Moisture meter reading 25% still. Wood hisses and spits in the stove. What gives?
This wood came from a sanitation harvest removing diseased or dead trees, particularly a fungal canker on the sugar maple. Can a fungal or bacterial disease inhibit the seasoning process? I have read about "wood that never seasons" and am afraid I might have just that.
Open to thoughts or suggestions.
My solution, and it works well, is to put something on top of the stack that puts a pitch on the tarp, and flairs the sides out a little, so the condensate and rain don't constantly re-wet the wood. I've found the advice to keep the top open for a time, so that rain keeps re-wetting the wood, to be counterproductive.
