Second burn underway..... took a while to get the cat lit off, a couple of hours with a small fire but eventually it went at ~ 620F.... Popped to 850F, no smoke. Windows closed, for now....
What did you do to your stove @Woodsplitter67? Looks gorgeous, as always.
I see you has the refractory out, did you replace it?
Any surprises?
Cat lit off no problem. Got a few splits on it now. Sitting in the 1000s. Debating how much I want to put in before bed. Already up to 64 in the house
View attachment 316450 View attachment 316451
Yeah pretty easy once you know how.Yes.. I did a rebuild.. not a complete tear down .. I did all the gaskets around the refractory engine and new refractory SS gaskets and fiber gaskets.. along with the usual damper housing and everything else that cam out of the stove. I did all new SS bolts and nuts.. I did it over like a months time .. here and there. It was a lot easier then I thought.. The first burn went really well..
![[Hearth.com] 2023/24 VC owners thread general discussion [Hearth.com] 2023/24 VC owners thread general discussion](https://www.hearth.com/talk/data/attachments/316/316557-6d45ba7418bf4fb7233eab85e2653d81.jpg?hash=zzTiV9MVVE)
Second year running new Encore 2040 Cat C. Installed Auber At100 last year for the Cat, added another this year with probe for my double wall stove pipe. Installed 18" above flue collar. Chimney is straight 17ish feet with one bend 5ft above stove. Flue temps seem to run high in comparison to Cat temps. Flue temp is on left. Seems like other graphs I've seen posted have a much lower flue temp. Currently burning load of Cherry and Ash. 17% moisture
View attachment 316529 View attachment 316530
Thanks, sure does help understand what's going on! Yes, it's a 6inch pipe.nice looking set up man.. Glad to see the probs going.. going digital makes such a big difference.. is that a 6 in stove pipe
sweet.. who did you get the log lenth from..
I cut the trees down myself at my buddys house and we loaded up a dump trailer and took it back to my place
nice.. self reliance.. like it.. I do all of my own wood also..
Looks like a cool wet weekend is in-store for us.. we'll be burning here in Southern NJ
Tonight should be a great night to burnAbsolutely, I try to do as much as I can myself. I don’t like to rely on others.
The stove will be definitely burning this weekend.
Low 40s at night high of 60 sat and sun. Probably light it tonight burn a half load and house will be warm in the morning still. Then repeat again tomorrow night. I haven't turned the blower on the stove yet haven't needed it.All through the weekend.. we'll be having some fires here and there.. keeping the windows cracked, so not to overheat the house..
we will start bringing up wood to the house at some point..
Your area should be colder then ours.. what temperatures are you looking at
