Any experience with really small heaters (<2k btu/hr)?
Microheat
4
Edson AB
I'm building a well-sealed and insulated microhouse. A heat loss calculator estimates I'll need 1800 btu/hr at -40C (I've gotten several nights a year at that, or lower) and 320 btu/hr at 5C. I'm off-grid, with a small solar power setup, so electric heat isn't an option, while I have vast amounts of wood. The "small" stoves and heaters I see online are designed for much higher outputs. So, has anyone here had experience with heat demands <2k btu/hr?
One issue is flue size. Flues shouldn't be more than 3x the btu/hr rating of the heater. One online calculator gave me a flue area of .25 square inches. Using the btu/hr value / 30,000 gives me 1/4" diameter flue. Is that totally unreasonable, or reasonable? My outdoor boiler continues to burn well even when I've sealed the intakes and capped the chimney, so leakage might be the equivalent of 1/4" diameter. I could use 1/4" tubing inside some 2" diameter steel tubing, packed with rockwool. The smallest commercial flue that I know of is 3", which seems way oversized for 2k btu/hr.
If the firebox is well-insulated (a foot of rockwool), it seems reasonable for a chunk of wood to burn while fed air through 1/4" tube. The air tube could even be smaller, since that's cold air. If spruce doesn't burn well enough under those conditions, I could limit myself to aspen and balsam poplar, which can smolder with minimum air. I'd like a heater that will produce heat for hours without tending.
Thoughts?
This has been discussed a few times. Wood is not a great solution for heating at this low requirement. The best you may be able to do it heat with a small stove in pulses. This will require frequent reloading as heat is needed. One option might be to burn compressed sawdust logs or bricks to extend the burn time. Take a look at the Dickinson Newport boat heater. That might work. It's output is from Low: 3000 BTU to High: 8000 BTU. It will run on small wood sticks, charcoal briquettes, or a compressed sawdust log. It takes a 3" flue and they have all the pieces to put a system together. Or consider their diesel or propane heater.
The flue size calculator is off by a whole lot. The most typical flue size is 6", serving stoves from 5,000 btus to 60k btus.
Reactions: Max W
Would a small (but vented) gas or propane heater be possible?
For so little BTUs, you won't have to get the tank filled often...
And it's set and forget with a thermostat, so little tending.
Reactions: Max W
I had a stove similar to the Dickinson in a 27 ft sailboat but barely used it. I burned chunks of hardwood. It was bulkhead mounted and could drive you out. It also left me staying up late one night waiting for it and the bulkhead to cool. Tiny Wood Stoves sells a 3kw Dwarf which drafts with a 4” flue.
Maybe you could even out the heat load with thermal mass? A masonry heater built into the floor with enough mass could slow down the release, but if you need fewer btu at 5C than a human body gives off (450htu) than I’m not sure how you’d regulate it. Your body would be giving off 25% more heat than you structure needs. You’d have to start warming the masonry days in advance and then it’d be hot for days afterwords. It doesn’t sound comfortable. You probably wouldn’t be comfortable without heat extraction at 5C.
Maybe some sort of homemade exterior boiler that has a thermostat controlling circulation so the temperature is controlled? It seems way more complicated than an electric resistance heater tied to a battery. That’d be simple, turn on and off easily, and due to the insulation, it wouldn’t take much power.
How are you planning to cook inside? That will put way too much heat into the structure to be comfortable.
That's useful feedback. Propane is an option, but I have abundant wood, and enjoy wood-collecting, so I'd like to use wood.
Cooking will be in an outdoor kitchen (admittedly inconvenient at -40), partly to avoid overheating in warm weather, but more to avoid moisture problems in such a small living volume. I'll be building a new charge controller for my new panel, and I'll send power not needed for loads or battery charging to an electric heater if needed. The wood is for nighttime heat and overcast days, during the cold season.
I suppose I also want to experiment to see whether a small wood heater is viable. At that size, I see it more as a chemical processor: a hot reaction chamber to convert wood to volatile gasses, then a secondary burn chamber, then a heat transfer chamber.
That's what I've got in my present cabin, operating right now. It has kept me warm, but it's also frozen or leaked at the worst possible times (can't dig up pipes when the ground is frozen), so I want something more reliable.
If an indoor heater isn't viable, I'll probably make another outdoor boiler, much smaller and more reliable. The present system has taught me a lot about what to avoid.
Yes, but that ignores the "shouldn't be more than 3x the rated btu/hr" rule. The problems from an oversized flue affect the user, while the companies selling systems care more about legal liabilities, so they'll use whichever commercial product their lawyers approve. I think it's unlikely that there are any approved flues commercially available smaller than 3". Too small a market.
For a tiny heater, a 1/4" or 1/2" tube doesn't seem unreasonable. I was hoping someone here had already experimented with tiny heaters with small flues.
Not ignoring, just stating the fact that the calculator is wrong. 3" is what will suffice and the smallest easily available
Consider making the cooking shed a lean-to that is closed-off in the winter, with an open doorway to the main structure. That way heat can be vented from one to the other when desired.
Reactions: stoveliker
Flue area needed is dependent on the area of the opening you load your fuel. Too small of an area and you have smoke roll out. Efficiency of the device dictates natural or forced draft.
If you’re going to inject your fuel through a tube and not load solid fuel you can have a small flue and correspondingly small intake.
I see an issue with two of the wishes:
1. a fire at night (so needing many hours), and
2. the order 1000 BTU/hr need for heat.
That won't work.
You need some volume to keep a fire going for 6-8 hrs. As in "keep it burning". Doing that with 10 matches won't work. Not because you can't necessarily limit the oxygen supply to burn slow enough (needle valves could), but there's not enough heat produced to keep things going. It'll go out.
I think that's the bigger problem here.
The 1/4" flue size calculator scales things linearly down from the 3-8" normal sizing. It (I think) disregards the additional impedance coming from the much, MUCH higher circumference to cross section ratio. That'll kill most of the flow, and lead to the fire going out as well. I.e. there is a limit to how one can scale down flue cross sections; it won't go linearly all the way to near zero.
I think the even though you have wood available, it's not likely going to work out.
I do like the lean-to suggestion; have a properly insulated door and you can play with the heat that way.
What will be your cooking fuel?
You could even put in a cook stove operated on wood (they'll burn longer but not even that long) and regulate the inside temps by how far you open the door between the kitchen and your main area. That way you do heat with wood, and have some control. Even if it overheats your kitchen area a bit.
If that is a very-well-sealed area, do put in an outside air supply for the stove.
