Hi all,
A month ago I had my chimney lined and installed a little Jotul F100. I knew it was way undersized for my home, but due to mantle clearance issues, this was what worked, and I figured the main thing was getting the liner done well and then I could reassess the stove situation (plus I got the F100 for $150 on craigslist, so no big loss to swap it out). I love having a wood stove, and quickly realized that not only is the F100 not cutting for my house but not even my first floor nor even the stove room, which I can only get up to about low to mid 70s at best. I am ready to go much bigger now, even if that means taking out the mantle, but it might not. One absolute restriction I have, I believe, is that I need a rear venting stove that can fit in a 30 inch opening, and an insert wont work due to a shallow fireplace firebox.
My home is a bit over 2000 square feet, three story victorian from 1890s with original windows (a bunch of them and they are large at 34.5"x67") with not so great storm windows added in the 80s or 90s, I had blown in insulation in all the walls, and it's fairly drafty. We mainly used the first two floors, but the third floor is a nice finished non-heated attic, and I'd use it more in the winter if it were warmer up there. I have a forced hot air furnace on floors one and two, and 9 foot ceilings throughout the first two stories. My first floor doesn't have an open floor plan, but there are open doorways throughout (with no doors on them), the stove is in the center of the first floor, there is an oversized open double door opening that opens from the stove room to the living room next to it, and the stove room and adjacent living room both have open doorways that lead to an open staircase up to the second floor. The staircase to the third floor is also open.
My thoughts on getting a larger stove are to either remove the mantle so I don't have those clearance issues, or to run a horizontal double walled pipe far enough to get me far enough past the mantle, but not so far that I loose draft (i.e. no more than 18 to 24 inches). The opening of the T from my liner to my firebox opening is 6.5 inches, so I'd need 18 inches of horizontal pipe to just reach the end of the 12 inch mantle. I have a 30 foot 6 inch, smooth walled liner (which I hear gives 20% more draft), and draft has seemed good so far. I'm including a layout of my house, which is relatively accurate, and a pic of my fireplace with all dimensions.
One other possibly relevant detail is whatever the temp of my stove room, the upstairs is consistently 6 degrees cooler - so if it's 71 in stove room, it's 65 upstairs. Not sure if this would carry over to other set ups.
Here's what I've already researched and am debating:
1) Woodstock Ideal Steel. I love the stove, the possibility of serious warmth and long burns, and like the idea of a cat. I spoke with Woodstock, and after looking at my setup via this info above and pictures, they told me the stove was the right size for my house, that I could get it past the mantle and be fine leaving the mantle up with a rear heat shield on the stove and heat shields for the mantle, and I'd have no problem with draft with the horizontal run (they thought I might even want to add a damper with my chimney height), however, they felt that the stove was too big for the stove room and might give me temps as high as 90 in that room! I asked about running the stove low, and they said that I knew the airflow of my house better than they did, but they still cautioned that it could be very warm in that room (by the way, my family and I like warm, that said, 90 might be a bit ridiculous!)
2) Jotul F45. I believe I can make clearances to my mantel with heat shields and the short leg kit. I like what I've heard about this stove, but fear that it might only heat my first floor, or have a lot of that heat escape upstairs and I may continue to be frustrated by no place in my home being warm enough due to it not being big enough.
3) Jotul F55 - I'm confused on Jotul's technical manual for this stove - at one place it says there is no short leg option for this stove (which means it won't work) and in another part of the same manual it says there's a short leg kit that makes it about 4 inches short - what gives?!?! If this is an option, I'm not sure about if I could pull it out far enough to make it work with the mantle or if I'd need to remove the mantle.
Beyond this, I'm open to thoughts, and would love some suggestions, opinions, technical details and potential benefits and pitfalls. My mantle is beautiful, from the 1890s and I hate to tear it down, but I think warmth and comfort will take precedence if necessary.
Thank you hearth friends!
Kenny
![[Hearth.com] Help me upgrade and upsize my wood stove! [Hearth.com] Help me upgrade and upsize my wood stove!](https://www.hearth.com/talk/data/attachments/223/223048-27b54cdf6d74e2ae4ad221975bc3d796.jpg?hash=nG4PeHUoIS)
Kenny
![[Hearth.com] Help me upgrade and upsize my wood stove! [Hearth.com] Help me upgrade and upsize my wood stove!](https://www.hearth.com/talk/data/attachments/223/223058-b11e45c378ba820b838c5d11a2eb8543.jpg?hash=E_EfP1_nlk)
![[Hearth.com] Help me upgrade and upsize my wood stove! [Hearth.com] Help me upgrade and upsize my wood stove!](https://www.hearth.com/talk/data/attachments/223/223059-89f4c29134d705b41523d446f719467a.jpg?hash=iD4vVbhRlj)
![[Hearth.com] Help me upgrade and upsize my wood stove! [Hearth.com] Help me upgrade and upsize my wood stove!](https://www.hearth.com/talk/data/attachments/223/223064-7c01196e44c983aa5bafb3fabd710307.jpg?hash=YlUcFsjyYo)
![[Hearth.com] Help me upgrade and upsize my wood stove! [Hearth.com] Help me upgrade and upsize my wood stove!](https://www.hearth.com/talk/data/attachments/223/223065-9b27e49d508c31aaf2efab5c14055467.jpg?hash=Md-o8yIHL9)
![[Hearth.com] Help me upgrade and upsize my wood stove! [Hearth.com] Help me upgrade and upsize my wood stove!](https://www.hearth.com/talk/data/attachments/223/223066-23985ea90205c7200c3211803df755ca.jpg?hash=MqCIj9uK98)
![[Hearth.com] Help me upgrade and upsize my wood stove! [Hearth.com] Help me upgrade and upsize my wood stove!](https://www.hearth.com/talk/data/attachments/223/223067-f8222be21ed80c755bcd3a15088daaad.jpg?hash=mWZZGaLEA0)
![[Hearth.com] Help me upgrade and upsize my wood stove! [Hearth.com] Help me upgrade and upsize my wood stove!](https://www.hearth.com/talk/data/attachments/223/223068-df15e93afb692c262b47778816486d2f.jpg?hash=b3mkwObuEk)
). The Woodstock person suggested the Fireview, but was clear that it would not heat my whole house. Here below is what the person from Woodstock wrote me regarding the Ideal Steel. I value their opinion, but not necessarily more than (or even as much) as the incredibly educated, informed and experienced crew here! I'd love second (and third, fourth...) opinions here.
