Ok, I just read this a second time, and I think a light bulb just went on for me that I was having trouble understanding before (I "think," as I may not be right about this). This is the piece about the room air picking up a lot of heat from the stove (and other objects in direct site of the stove), via direct conduction. So, am I correct in my understanding that the air touching the stove (and other warm objects in the room) picks up heat via conduction by virtue of air that is touching the stove, much like the end a metal spoon would conduct heat from the other end submerged in boiling water? This air then moves around the house warming things up in other places. Correct? And, with a more conductive stove it is blowing hot air out, correct? So, if I'm correct about this, is there anything beyond a blower and perhaps some sort of jacket around a stove that collects hot air to be blown out, that makes one stove convective and another radiant? Is certain material inherently conductive in its nature and other material radiant? Is a soapstone stove or cast iron stove always more radiant while steel always more conductive? Would the Ideal Steel be pretty equally both as it's steel with a soapstone liner?
Ding! Ding! Ding! You’ve got it, now.
Q1: So, am I correct in my understanding that the air touching the stove (and other warm objects in the room) picks up heat via conduction by virtue of air that is touching the stove, much like the end a metal spoon would conduct heat from the other end submerged in boiling water?
A1: Basically, yes. The air picks up energy off the stove, convective air currents then move that warmed air to another part of the house, where the air then conducts that energy to other cooler objects. Convection and conduction work together, radiation does not require either.
Q2: This air then moves around the house warming things up in other places. Correct?
A2: Correct.
Q3: And, with a more conductive stove it is blowing hot air out, correct?
A3: You got it. It just short-cuts the same process that occurs eventually with a radiant stove, but at a higher air temperature.
Q4: So, if I'm correct about this, is there anything beyond a blower and perhaps some sort of jacket around a stove that collects hot air to be blown out, that makes one stove convective and another radiant?
A4: The jacket and blower are usually the biggest factor. They also sometimes add fins or other features on the hot surface of the firebox (think finned heat sink) to enhance the heat transfer from metal to air.
Q5: Is certain material inherently conductive in its nature and other material radiant?
A5: Yes, some materials radiate better or worse than others, this is measured as the material’s emissivity. However, put a blower on the stove, and you’ve just overwhelmed the much more minor differences in material emissivities. Sort of like worrying about the color of the paint, after someone spilled a can of it on your floor.
Q6: Is a soapstone stove or cast iron stove always more radiant while steel always more conductive? Would the Ideal Steel be pretty equally both as it's steel with a soapstone liner?
A6: Good questions. I am not sure of the emissivity numbers of each, but you could check. I was speaking to the design of each. Steel fireboxes are more often wrapped in a cast iron convective jacket, than traditional cast stove fireboxes or soapstone stoves.
