My stove over fired. What do I do next?
tg27
35
USA
My house came with an old Jotul Firelight 12. I've been using it for the past 6 years with no issue. But last week, this happened:
  • After loading it up, I heard it “whooshing,” like air rushing up the stove pipe
  • It was running hot (around 650), but I had just closed the damper so I expected the temps to drop
  • But they didn’t…it hovered around 650. That’s when I noticed the back glowing (see pic)
  • I eventually quickly opened and closed the damper to disengage the catalyst, which seemed to work (or it started cooling off by coincidence)
  • One thing to note, the damper was really hard to close after opening it. Not sure if something was stuck or what. I was scared it was going to get stuck open which scared the hell out of me
Few things about my stove. It's old! The back plates has a small crack. But my chimney guy did inspect the stove when he cleaned the chimney and said I seemed good to go. Also worth nothing, this was my 3 or 4th load of the day when this happened, and it was probably my 5th fire of the season. Up until that last load...everything was a-okay!
SO...my question is, what do I do next? This feels pretty serious to me, but am I over thinking it? Do I need to have someone come out to inspect it, or can I do a sort of "common sense" inspection myself. This is new to me.
Thank you in advance for your help! Always appreciated.
  • [Hearth.com] My stove over fired. What do I do next?
Maybe the crack got bigger, allowing more air in and overfiring the stove
I would not use it like this until you figure out what went wrong.
I would not use A stove with a crack, not a sweep who says that it's fine when it's cracked
Do you have a flue thermometer? If so how high did that go up?
By back plate, do you mean the inner back plate or the actual back of the stove?
Did you hear any noise in the stove pipe or chimney? When was it last cleaned? How fully seasoned is the firewood? A chimney fire can cause an unusual suction and whoosh that can result in an overfire.
The stove should be allowed to cool down and thoroughly inspected. It wouldn't hurt to have the flue system inspected as well.
From the photo it looks like the back of the stove. Not familiar with that stove, but it looks like a catalytic chamber or something there?
Yes, that is the cat area. The design is somewhat similar to VCs and Harman cat stoves. It could be that too much smoke is getting past the cracked back in the wrong location or that the combustion package has broken down.
