armanidog
Can you pull back the collar on the stove pipe and see if any insulation or sheetrock may be getting scorched by the stove pipe?
So, you're thinking that the draft is weak, so smoke is coming out of the top of the stove? It seems that most of the smell comes out of the sides of the top section of the step-top stove.
I'm not referring to straight wood smoke. This "sweet" smell or BBQ smell is exhaust that has passed through the combustion system. Typically anyway...I'm not sure about the smoke in the house theory. Assuming you have anything resembling a good draft, any leaks should result in air being pulled into the stove. I have run an old, non-airtight stove that would light up the cabin at night with light leaking out of the cracks and gaps and even with a short single wall chimney it didn't let smoke in once past the initial kindling stage.
When I have seen smoke come into the house due to a draft problem, it's been very obvious and out the air intake. If you can feel/hear air being pulled into the intake, it's also getting sucked in anywhere else. And if the wind is interrupting the draft, you should see a dramatic change in how the fire is burning at the same time.
If the smell is coming out of the convection chamber, then we're back to the dust theory. This stove was a floor model, no? I'm wondering if it has a couple years worth of accumulation in a hard to reach location. Is there anyway you can take a peak inside with mirrors and a bright light? I'm thinking the "mirror on a stick" sold in auto parts stores might be useful here.
I forgot you said that you can smell it at the stove. Nonetheless, there's a few threads a season with folks saying they have a sweet or BBQ smell coming from the stove. It's typically a cat or downdraft stove though.How are the windows In your house? When I first bought my house the windows weren't sealing up well and smoke would get drawn in the windows in the outlying rooms.
Was this stove repaired at some point? It seems a little odd that nothing is painted back there. I would not expect to see the raw welds and smoke marks, but I haven't taken the back off of a Quad and maybe that's how they ship them now.
I agree. I'm no welder, but I have my hands on new stoves everyday. I've never seen welder smoke marks on a stove, some splatter on occasion, but typically in areas there's no way you could snap a pic..Somebody is lying...that stove has been repaired. I studied metallurgy for a few years and welded professionally for a number more in a manufacturing environment. That welding job was done after the fact. They did not completely clean the original fillet weld out to my eye and rolled the new weld...the dots are welding splatter..that in its self is not a issue but once again it points to being welded after the fact as everything is usually media blasted for final prep prior to painting..I don't like the smell of this...pun intended.
It is possible that this was done before it left the factory after failing inspection...BUT it is awfully sloppy work and should never have left before being cleaned up. As you noted a small amount of welding splatter can be present as it is sometimes impossible to clean it all up...there was no attempt here..I don't like it...I agree. I'm no welder, but I have my hands on new stoves everyday. I've never seen welder smoke marks on a stove, some splatter on occasion, but typically in areas there's no way you could snap a pic..
I've seen used stoves be returned to the factory for repair that came back in better condition than that.It is possible that this was done before it left the factory after failing inspection...BUT it is awfully sloppy work and should never have left before being cleaned up. As you noted a small amount of welding splatter can be present as it is sometimes impossible to clean it all up...there was no attempt here..I don't like it...
I absolutely would bring it up..I think its a bad weld with porosity(void fraction) in it which in turn is allowing a small amount of smoke to escape upon exspansion.I have seen many items rewelded after failing inspection standards. It is very common practice to save the product.Well, now I really don't know where to go with this, LOL. I will point out that those welds you see are normally hidden behind the back cover and on the top inside of the stove. Would an area like that normally be painted? It's an area that most owner's would never see.
I guess I'm still more concerned with the original issue. Could smoke be leaking where the stove pipe is coming through that top part?
When they take a look at it on Monday, should I bring up the fact that it appears to be repaired? Or that I don't think it should be rusted there? Will those areas rust through before the life of this stove should otherwise be up? Why would a stove like this have been repaired?
I have seen how Travis builds and finishes stoves. All surfaces are painted after welding and cleanup. This looks unfinished or a practice stove. I would expect the flue collar pipe to be welded in too.
You should not be smelling anything this far in with this stove. If it were me they would be replacing it.You should not be expected to put up with this.
Makes me wonder if there was a reason this stove was a floor model. Could this have been a reject that was never intended to be burned? Just wild speculation on my part.
I wouldn't accept anything less than them replacing the stove or refunding my money. The stove is not right regardless of cause. I am funny like that when I don't get what I paid for. Stand your ground on this one.That definitely could be. I wonder if that would have anything to do with (what I think is) excessive creaking and cracking from the stove whenever it's burning (there's a video in an earlier post).
Could be. I'm just hoping they don't try to convince me that this is all perfectly normal. That was their first reaction to the smell issue. I don't think I'll ever burn the stove again in this condition. The smell is that bad and worrisome.
...1. Biggest question: Is there supposed to be a weld where the pipe (I'm sorry, don't know the correct terms for these parts) comes through the thick steel? There are welds everywhere else, but it seems odd that there wouldn't be one there.
Here's a view from the inside top. As you can see, no weld on top or bottom.
2. The welds that are not painted have a pretty rusted color to them. Is this normal for non-painted areas?
3. On the top, there are hundreds of little beads. It looks to me like leftovers from the welding. I'm assuming there's no issue here, but figured I'd ask. You may need to click on thumbnail to see it bigger.
So, I took off the back cover to look into the chamber at the top of the stove. There are two air vents that you can feel air coming out of (while it's burning) on the front of the stove at the "step." I think this is normal and it's supposed to pull air up and out in this way. Anyways, that location seems to be where I get the strongest smell.
I was hoping I would take it off and see some melted toy some kid stuck in there while it was on the floor of the store for two years. Unfortunately, it wasn't that easy. I have a few questions though.
Unfortunately, we're still waiting for them to have availability to check it out.
It appeared to me that it is flux-core...a technique reserved for outdoor windy/conditions...this doesn't add up to me.If that is the actual pipe carrying flue gas/smoke out of the stove, then YES, it should ABSOLUTELY be welded to the top of the firebox.
I can not imagine ANY reason there would NOT be a weld at the pipe joint you mention. That is the actual flue pipe connected to the firebox at the top the stove, correct? ...not some shield or cover or the flue pipe-to-outer-shell joint?
When I converted my stove from a 'slammer' with a rectangle outlet to a full-lined stove with a 6" flue outlet, I welded that pipe on both the inside and outside of the firebox. The only thing I could possibly think of would be if it happened to be a tight press fit, so the factory could save $1.50 on welding it or if it had some unseen gasket somewhere.
Regarding the welds you found, that yellow-white powder is typically a sign of stick welding or flux core wire welding. The 'hundreds of little weld beads' is also somewhat indicative of stick welding - you get a lot of weld spatter. Though it also suggests the weld parameters were off - likely the weld was too hot causing the spatter instead of the metal laying down in a nice pool.
Either way, it seems a bit fishy to me. Any modern production line is geared for speed and efficiency. Stick welding, flux core and a bunch of weld spatter would not typically be in line with speed/efficiency. I suspect at a minimum they would be doing MIG welds and if I had to do it, I would do spray-arc MIG to boost the welding / metal deposition rates even more - that would leave a very clean weld, no spatter and no 'dust'.
. )We use essential cookies to make this site work, and optional cookies to enhance your experience.
