BeGreen said:I've posted before that I'm not a fan of ceramic baffle boards so no rant here. But I do think modern stoves are an expensive purchase and don't like the idea of consumables tied to its long term operational efficiency or durability. That sounds too much like today's modern computer printers. It was influential in my deciding on the T6 cuz I'm a low maintenance operator. I have enough things around to keep working well without adding more maintenance to the list.
The other side of the coin is with low priced stoves like the Englander and Napoleons, I think a baffle board solution there is acceptable. These companies provide solid heaters at an affordable price. There has to be some compromises in design. Considering how cleanly these stoves burn, I think the baffle board is an acceptable compromise. OTOH, in a high-end stove, I'm expecting a better solution.
BrotherBart said:Jotul F3CBs have a galvanized steel baffle in them. It is going to be real interesting to see how long that lasts.
velvetfoot said:I've had my Quad for several years now and have not cracked the board yet (knock on wood). Maybe it is because the tubes below shield it some. Compared to my last Quad though with the 30 pound steel baffle, it's a lot easier to handle when cleaning the insert, though it has to be handled very carefully.
Now, about those flimsy firebricks....![]()
summit said:velvetfoot said:I've had my Quad for several years now and have not cracked the board yet (knock on wood). Maybe it is because the tubes below shield it some. Compared to my last Quad though with the 30 pound steel baffle, it's a lot easier to handle when cleaning the insert, though it has to be handled very carefully.
firebrick is another... although it is an itam very commonly avail. my summit came with pumice like bricks in the bottom and sides, and it took us a year to start carrying them because of that, but the baffles sold us after that
cmonSTART said:As much as I like my 30-NC, I'm not so much a fan of the split ceramic fiber baffles..
stoveguy2esw said:cmonSTART said:As much as I like my 30-NC, I'm not so much a fan of the split ceramic fiber baffles..
they had to be split , a single would not fit through the door. as for impact breakage it would take some carelessness on the part of the loader as they are situated above the door opening. we specify that the stove should also only be loaded to the top of the bricks to provide room for secondary combustion this leaves 3 to 4 inches before hitting the tubes and the width of the tubes before getting to the baffles. as for durability , they have held up quite well we really have not had a very high percentage of replacements (though we did have to put a label in the stove on top of the panels as folks occasionally thought they were "packing materials" and ripped them out)"oops"
flewism said:OK, I disassembled the insert today and have a sweep coming this Tuesday. Last year when the sweep came I just pulled the baffles, this time I pulled everything.
A link to the baffles online (broken link removed to http://www.stove-parts.net/Baffle_Kit_for_Napoleon_1400_1401_p/w018-0078.htm)
A picture of my current baffles, this insert has about 10 cord through it.
The metal bracket on the right covers the air tube for the secondary burn. The white material inside this bracket has not been identified as it is not on the parts list for this insert that I can find, any help will be appreciated.
lorskimac said:I'm sure everyone here already knows the answers but I can't help asking anyway...
What's a baffle?
What's a firebrick?
Sorry if this is a bit exasperating for you, but I'm a fast learner!
What's a baffle?
What's a firebrick?
the bull said:so if a person was going to buy a stove which is the best to buy . have another post asking help for best stove to get. if they are going to be a constant hassle my dad will just keep his old fisher. he will not want to buy another if things are going to break and constant mantinance.
