New to stoves, please help me
its new and your going to get some burn-in smoke/smell. open windows air it out. don't open the window by your stove pipe. what are the settings on the stove set to
Reactions: midcoastman
the cement you used is to glue rope and band seals/gaskets, not really meant for stove seal. but i suppose it will work just be a pain when you take the pipe off the stove.
That stove design has been around a long time,works well.Post a picture of the "vent thing" you are talking about.If you did not burn the stove outside,you will get some smoke,from paint and oils,inside.
how does the fire look? yellow and busy or red/orange slow and lazy?
Heres what i was talking about and ssyko heres how the flame is burning
  • [Hearth.com] New to stoves, please help me
thats not a bad fire. It takes a little while for the stove to get up to temp and it is its first fire so don't get discouraged. your going to have to learn the stove settings to fine tune to your liking. now every time you change a setting it takes 30-40 min for the stove to adapt. its slow but you'll be happy when the bugs are worked out
Reactions: Doylee4693
i just got my older 25pdvc in my office and the prom dumped so i haven't got mine worked out yet waiting on parts
i live on TUG HILL i know all about mother natures NY fury. lol
9 n 9 will probably cook you out of the house..
Haha well I guess I thought it would heat up to temp faster but shes getting there... when I clean her in the morning i better do it fast, god forbid i go more then an hour with no heat going, may take another two hours to get back up to temp haha
Several things-1 you should have at least 3 foot vertical rise in your exhaust,per manual.2-you should have installed the parts for outside air,per manual, 3--MOST important--you are missing the impingement plate that covers the big hole behind the flames,will never get good heat without it.
yes that plate is imperative for heat..
Yes it has 3 foot piping inside and yes thats a fresh air vent.. ok so thats what that is, an impigement plate.. il have to close that but for now shes giving decent heat,unless its dangerous leaving it halfway open like that?. thanks for all this help guys, my anxiety is supressing
Reactions: Mt Bob
Also I cant tell where the smokes commin from I can just see a light fog in my living room
Easy to find the smoke leaks. Bring a flash light and have the room dark as evening. Then turn stove on. Look at all your joints on the exh pipe with the flash light and you will find the leaks. I use high temp clear silicone over any joints but you can also use high temp tape. One problem with buying a stove out of the area is no service. But having said that you should find a phone number to call and a company rep will help you suggest answers to your problem.. A good idea would be to find someone who is using a stove like yours and ask them for advice.
Hi,rona,he fired up the stove,brand new,and did not open any windows and doors.I think he sealed his pipes ok.
Is it just me or are these things massivly infficient. Im burning one full 40lb bag every 14 hours, and the settings are l for heat and 2 for blower. Am I doing something wrong or am I looking at spending nearly 10 dollars a day to heat my tiny home..
Some are not very efficient.Where I live propane and electricity is expensive,so works out well for me. (broken link removed to http://www.harmanstoves.com/Shopping-Tools/Buying-Resources/Pellet-Fuel-Savings-Calculator.aspx) https://www.treehugger.com/clean-technology/pellet-stoves-vs-wood-stoves-which-is-greener.html and there are other online calculators you can use.
Wow where in the hey do they get these numbers. It said 15-25 hours burn time on one 40lb bag, at this rate il be lucky to use two bags a day.... not including labor and the pain to reload it all the time... alls im saying is if natural gas is an option. Run to it, do t walk.. tell stnick il be broke this year lol
Nat gas is almost always the better choice,right now.
Check the bottom 3 numbers (buttons below heat and blower buttons)
Also check what mode your stove is in. Should be set to D mode.
A quick search on this site for englander 25pdvc will provide tons of information.
I have the same stove and use a bag about every 22 hours on medium heat settings.
Sent from my SM-G950U using Tapatalk
