Its called rutland stove cement and i got it from tractor supply. I used daravent and I taped all joint even at the elbow
Easy to find the smoke leaks. Bring a flash light and have the room dark as evening. Then turn stove on. Look at all your joints on the exh pipe with the flash light and you will find the leaks. I use high temp clear silicone over any joints but you can also use high temp tape. One problem with buying a stove out of the area is no service. But having said that you should find a phone number to call and a company rep will help you suggest answers to your problem.. A good idea would be to find someone who is using a stove like yours and ask them for advice.Also I cant tell where the smokes commin from I can just see a light fog in my living room
Hi,rona,he fired up the stove,brand new,and did not open any windows and doors.I think he sealed his pipes ok.Easy to find the smoke leaks. Bring a flash light and have the room dark as evening. Then turn stove on. Look at all your joints on the exh pipe with the flash light and you will find the leaks. I use high temp clear silicone over any joints but you can also use high temp tape. One problem with buying a stove out of the area is no service. But having said that you should find a phone number to call and a company rep will help you suggest answers to your problem.. A good idea would be to find someone who is using a stove like yours and ask them for advice.
probably should have fired it up outside to burn oils etc off the metalHi,rona,he fired up the stove,brand new,and did not open any windows and doors.I think he sealed his pipes ok.
Some are not very efficient.Where I live propane and electricity is expensive,so works out well for me. (broken link removed to http://www.harmanstoves.com/Shopping-Tools/Buying-Resources/Pellet-Fuel-Savings-Calculator.aspx) https://www.treehugger.com/clean-technology/pellet-stoves-vs-wood-stoves-which-is-greener.html and there are other online calculators you can use.Is it just me or are these things massivly infficient. Im burning one full 40lb bag every 14 hours, and the settings are l for heat and 2 for blower. Am I doing something wrong or am I looking at spending nearly 10 dollars a day to heat my tiny home..
Nat gas is almost always the better choice,right now.Wow where in the hey do they get these numbers. It said 15-25 hours burn time on one 40lb bag, at this rate il be lucky to use two bags a day.... not including labor and the pain to reload it all the time... alls im saying is if natural gas is an option. Run to it, do t walk.. tell stnick il be broke this year lol
Check the bottom 3 numbers (buttons below heat and blower buttons)Is it just me or are these things massivly infficient. Im burning one full 40lb bag every 14 hours, and the settings are l for heat and 2 for blower. Am I doing something wrong or am I looking at spending nearly 10 dollars a day to heat my tiny home..
